help finding right part! carb related
Old 08-08-2012, 01:27 PM
yodamomma's Avatar
hi, sorry to post this, but i've searched for my old post, and can't find it anywhere...
My 22 r carb had issues, stalling after running when warm; i had a part replaced, it was under the carburator? I'm having the same issues now, and think it's the same part, because it was put in from a junker truck....I can't remember the name, and need to order the part. It was not the carb, it was part of the vacuum system, some kind of valve? I posted the name of it when i got it, but, like i said, i can't find the post anywhere.
Help please? Th anks!
Old 08-08-2012, 02:02 PM
myyota's Avatar
One of the most common problems on a 22r carb is that auxiliary accelerator pump diaphragm goes bad/gets a hole in it and leaks fuel into the vacuum lines, and that will cause your truck to run bad or have a miss when its running.
Old 08-08-2012, 02:44 PM
yodamomma's Avatar
that is certainly a place to check, but i'm pretty sure that was not the part that was replaced....i was thinking...some kind of switch?
Old 08-08-2012, 02:55 PM
yodamomma's Avatar
could it have been the solenoid?
Old 08-08-2012, 02:58 PM
myyota's Avatar
Is it possible for you to post a picture of the part you think is bad ?.
Old 08-08-2012, 04:14 PM
yodamomma's Avatar
sorry, wish i could. i know it was small, and had two wires coming from it!
is the solenoid next to the carb on the 87 22r?
Old 08-08-2012, 05:02 PM
myyota's Avatar
There is a fuel cut solenoid that screws into the side of the carb that has two wires on it, and what it does is shut off the fuel in the idle circuit on the carb when the engine is shut off. But if the fuel cut solenoid was bad your truck wouldn`t even start, so I doubt that is your problem.
Old 08-08-2012, 06:18 PM
slow-mo's Avatar
Originally Posted by myyota
There is a fuel cut solenoid that screws into the side of the carb that has two wires on it...
+1
There are only 3 electrical parts on the 22R carburetor. And only one that has two wires going to it. That one is, as stated by myyota, the Fuel Cut Solenoid. Part number 21934.
http://www.utoyot8.com/FullImage.asp...608-8705%2922R
The other two are the automatic choke (part number 21015), it has one wire going to it and uses the body for ground. And the Outer Vent Control Valve (OVCV) (part number 21347). It also has one wire and uses body for ground.
Old 08-08-2012, 07:51 PM
yodamomma's Avatar
slo mo, that is the part. what started happening was the truck would die when i took my foot off of the gas. Changed out the carb, still had problems. Changed out the solenoid, worked for awhile, and now cuts out after i take my foot off of the gas, so i'm thinking it is the same problem...
Old 08-09-2012, 09:57 AM
slow-mo's Avatar
While it is possible that 2 carburetors having that exact same issue, it is unlikely.
I would investigate the carburetor idle speed screw to see if the carburetor only needs a simple adjustment.
I would investigate the idle advance on the distributor to see if it is holding vacuum. If it does not, the rpms will drop to a lower speed than designed and may stall the engine.
Are you able to keep the engine running if you maintain a higher than idle engine speed with the gas pedal?
Old 08-09-2012, 10:39 AM
yodamomma's Avatar
not sure. in order to start up the truck (it is the farm truck, so it sits for a while) i was having to squirt a little starting fluid into the carb. The last time i got it started and was driving it, it stalled on low idle. I will try to start it up again and let you know.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
toyota32
07-06-2015 05:42 PM
ptb12
07-05-2015 01:49 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: help finding right part! carb related
