Headlight Warning Buzzer....
Old 09-27-2021, 10:16 AM
revsam937's Avatar
1) I have a nice 1987 22-R, base pickup, 5 spd MT, with California Emissions, and I have an inoperative headlamp warning buzzer and want to restore its operation. My FSM says it ought to be located around the Emissions Computer behind the passenger side kick panel. Is that where it is? Is this feature an option that may not be on this truck?
2) I'd also like to find out if my truck has seat belt warning buzzer. I searched under the seat and carpet (both sides) and there is no wiring near the buckle part of the seat belts at all. Federal law says there should be such a buzzer.
3) The only buzzer I hear right now is the one that sounds off when I turn the ignition off and leave the key in the lock cylinder.
Old 09-27-2021, 10:23 AM
RAD4Runner's Avatar
Originally Posted by revsam937
1)...My FSM says it ought to be located around the Emissions Computer behind the passenger side kick panel. Is that where it is? Is this feature an option that may not be on this truck?
If you looked and it's not there, your truck probably doesn't have it, just like mine...
I made my own:
https://www.yotatech.com/forums/f199.../#post51903481
Old 09-27-2021, 11:31 AM
old87yota's Avatar
I made my own:
^^ Yes, the headlight buzzer was optional. Most trucks that I have seen do not have it. My 1987 2WD Truck doesn't have one either.
The seat belt warning buzzer is the same buzzer as the "key left in the ignition" buzzer. There should be a wire going to the driver's side seat belt buckle.
ajm5895
11-14-2017 08:07 AM
83Toyota88
08-18-2015 07:42 AM
Tanker5503
11-26-2010 05:17 PM
Adm Keth
11-09-2010 04:32 AM
Robrt32
05-04-2007 02:11 PM
Quick Reply: Headlight Warning Buzzer....
