Gap between engine and bell housing
Old 06-13-2013, 01:58 PM
Dauntless1971's Avatar
I just replaced my 4runner 1987 22re with 5 speed. The Ex ended up with my last one. I knew there were leaks when I bought it. So I was just underneath trying to determine what I needed to do to fix the leaks when I noticed there is a gap on the lower half of the bellhousing to engine perhaps 3/16 of an inch at the very bottom then less till no more gap about up half way. So I hate to ask a dumb question is this correct? Do I just start torquing the bolts? It just seems odd the top half looks fine.
Old 06-13-2013, 02:36 PM
So I just checked the bolts are tight, the gap appears to be mostly just at the two lower brackets that go to the engine.
Old 06-13-2013, 04:10 PM
Killgore Trout's Avatar
snap a couple photos, and get as close to where the brackets bolt to the block as u can, i want to see the mounting.
Old 06-13-2013, 04:57 PM
Old 06-13-2013, 05:37 PM
it looks like the stiffener plate is hitting the lip on the oil pan at first glance, ive heard of people having to tap the oil pan lip back a tad, if all the other bolts are really tight, you may have to loosen them a bit to get that gap to close, which sucks because the top 2 are a pain, that isnt a 4 speed trans is it?
Old 06-13-2013, 11:43 PM
wyoming9's Avatar
Red face
as long as your not having clutch problems I really would not worry about it.
Just look closer if and when you need to pull the transmission for a new clutch
Give that poor truck a good bath!!
Old 06-14-2013, 12:24 PM
Philbert's Avatar
Agreed, wash that sucker and then look for where leaks are coming from. Looking at it now, maybe it's a leaking rear main seal, and is dripping out the bottom of the bellousing.
Note that the 2 bellhousing bolts shown have much lower torque rating than the ones that bolt to the BLOCK. The ones you show bolt to the 2 mounts in the photo. How do I know? I snapped one once
That small gab is odd - could be the blocking plate got caught on something/bent at one point maybe?
Old 06-14-2013, 04:55 PM
I bet it has been like this since the new clutch was installed at a shop in Portland about 45K miles ago. I think the engine is leaking at the valve cover and I know the transfer case is also leaking at the rear seal because of worn bearings. I can grab the driveline and see the rear flange move at least a quarter inch. I am trying to decide about replacing the bearing and seal on the transfer case or picking up a used one for a c note. I also need to do a search about replacing gaskets on the engine.
Old 06-17-2013, 09:08 PM
thefishguy77's Avatar
Oil-eater is a good brand for me when I need to clean off the engine. Spray it on straight then let I sit scrub if needed hose odd with med/high pressure. Repeat till clean. Always wear safety glasses when spraying chems. It sucks when it gets in your eyes.
andrewtexas123
07-14-2015 04:29 AM
ZONAYODA
07-13-2015 07:17 PM
A2theK
07-12-2015 10:46 AM
Poncho0206
07-10-2015 06:21 PM
Edionne13
07-09-2015 01:59 PM
Quick Reply: Gap between engine and bell housing
