Fuel pump location on 85&88 4wd 22RE
Old 03-05-2013, 11:07 PM
joecool76's Avatar
Does anyone know right offhand where the fuel pump is located on 85 & 88 4wd trucks 22RE?
Old 03-06-2013, 02:42 AM
91 4Runner's Avatar
In the tank. Do yourself a favor an get a service manual it will really help with easy things like this.
Old 03-06-2013, 04:22 AM
joecool76's Avatar
I have a Chilton and it sea confusing and not to have all the info.Do you have any reccomendations for a service manual?
Old 03-06-2013, 05:09 AM
INFINITY's Avatar
chiltons suck, haynes suck less. they are both based off of the fsm
Old 03-06-2013, 05:37 AM
86STLRunner's Avatar
its under your bed, you will need to drop the tank, remove the bed, or cut a hole in your bed for an access panel. Here is a picture of an 87 reg cab with the bed removed if it helps you...
Old 03-06-2013, 06:39 AM
joecool76's Avatar
Thanks,it was helpful.Does the fuel pump just come right off of the top of the tank?Do these fuel pumps usually last a while or how often do they go out?
I have a 88 that's real similar to your truck.
Old 03-06-2013, 09:29 AM
85TurboRunner's Avatar
Unfortunately the tanks on yotas are a sealed unit. You have to replace the tank when the pump goes out. They usually last 10k miles or so.
You can use a torch to cut out the pump and weld a new one in but its kind of hard to get a good seal.
Old 07-03-2019, 10:33 AM
Brush Rat's Avatar
Not sealed! Lift the bed or drop the tank and on top is a round plate with pickup tubes etc. on it Take this off and lift the unit out Fuel pump is part of the unit. Pretty self explanatory when you see it.
Old 07-04-2019, 11:07 AM
5 Fists's Avatar
Yeah they are definitely not sealed in toyotas. Replaced the fuel pump in my 87 4runner about 2 months ago, you unbolt that round flange in Brush Rats image and pull it straight out of the tank, pump is attached to the bottom of a piece that connects to that round flange plate. A couple bolts and connectors, clean up the sock on the end, and Bob's your uncle.
PS: Oh man, I just helped necro an old thread :/
Charecter1
11-06-2023 10:08 AM
jbv808
08-06-2021 04:47 PM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
redneck17
07-17-2015 07:44 PM
Quick Reply: Fuel pump location on 85&88 4wd 22RE
