front sway bars?
front sway bars?
ive been reading you can take out the front sway bars for better flex in the IFS how is this done? and what does it affect highway/street wise?
taking the front sway bar off, or at least disconnecting it will allow each side to flex more independently. However, with it disconnected you will experience slightly more body roll. While off-roading it is highly advised to at least disconnect the sway bar, or even remove it. However on-road, most people prefer to have them. personally I removed mine all together and just made adjustments to my driving style to compensate for the lack of a sway bar.
If you want to retain it, but still be able to quickly disconnect it for off-road use, I would look into a quick disconnect system that replaces the end links of the sway bar and allow you to disconnect and reconnect it easily.
If you want to remove it, just unbolt both end links, and remove the brackets that hold it to the frame and out it comes.
Hope that helps
Hope that helps
Thanks. i removed it today was gonna see how it drove but on the drivers side the 2 12 mm bolts decided to break off on me so meh ill just leave it out for now didn't notice too much of a difference anyways...
Some tips for deciding on leaving them off or not:
http://www.4crawler.com/4x4/CheapTri...l#AreTheyForMe
I've not had sway bars on my truck for about 9 years now.
09-04-2015 09:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
