Front Suspension/steering
Old 04-25-2024, 07:59 PM
LaGonzales86's Avatar
I've been on a hunt for OEM parts for my 1986 pickup's front end but I cannot seem to find some parts. Specifically the inner rod ends and steering relay rod for manual steering. I have considered going aftermarket with the parts that I can't find but I am very hesitant on quality and brands. I've tried to contact my local dealership and have had no luck with said parts.
Any suggestions?
Old 04-26-2024, 03:01 PM
prcnctoyo's Avatar
I replaced my tie rod ends with MOOG. I used the Beck/Arnley relay rod (center/drag link), power steering. Both done in late 2020. No issues so far. Purchased from Rockauto.
Old 04-27-2024, 06:54 AM
jeremy harp's Avatar
Did you search on ebay ?
Old 04-28-2024, 11:15 AM
YT Community Team
Jimkola's Avatar
I'll look, but you gotta give me your model# first. Or at the very least let me know 2wd or 4wd. Model# would be better though. On the plate riveted to the firewall
Old 04-29-2024, 01:50 AM
strelok's Avatar
If you have a 4WD Pickup the parts should be interchangeable between my 4runner and your pickup. Partsouq.com is a good resource for those hard to find parts and they make it even easier to find them with a diagram. I ordered a 555 Pitman arm and two 555 Tie-Rods from them, came from Dubai so its a little bit of a wait but well worth it for near a near OEM Japanese made part. Total was $81 shipped. Part number was SS2720 for the tie rods.
Old 04-29-2024, 08:16 AM
I've heard some bad things about moog recently.. Beck/Arnley has been a mix
Old 04-29-2024, 08:19 AM
It's a 2wd which is why it's been a little difficult to find parts. Base model 1/2 ton. I'll get you the model# when I can
Old 04-29-2024, 08:48 AM
prcnctoyo's Avatar
2WD relay rods (drag/center link) thru 88 are OEM discontinued even 3 years ago when I replaced mine. The inner tie rod ends are OEM discontinued for 2WD thru 88, again even 3 yrs ago. The OEM outer tie rod ends are still available. You'll have to go aftermarket for what you're asking. I've got at least 30K miles on the MOOG tie rods and Beck/Arnley relay rod. So far I've no complaints. Do I expect them to last as long as the toyota originals, NO.
The following users liked this post:
LaGonzales86 (04-29-2024)
Old 04-29-2024, 04:29 PM
Originally Posted by jimkola
i'll look, but you gotta give me your model# first. Or at the very least let me know 2wd or 4wd. Model# would be better though. On the plate riveted to the firewall
rn50l - kra
nickbeauregard
07-05-2017 07:33 PM
5runner
03-02-2012 12:23 PM
ledzeppelin3270
10-09-2011 04:09 PM
sagorski1611
12-12-2010 12:36 PM
88T4R
06-17-2009 08:16 AM
Quick Reply: Front Suspension/steering
