front axle question? and a dumb one!!!!
i know,and trust me.i've search for hours and still no answer to my question
?how to id. a 1985 front axle?
what are the difference in a 85 to the rest aand what to look for...
i know the answer is in here but i dont see it..
all i see,it's better than the rest
doing the S A S on my 88 and i am in the proscess of buying all the parts
thanxs
thanxs
You really didn't search for hours.
:wabbit2:
If you have the urge to convert to SA, make sure you are getting a Toyota axle. There are others that will work but the Toy SA will be the easiest since all the spring mounts will already be in place.
If it is a Dana, make sure it is a passenger side Diff. No point in getting a Waggoneer Dana (for example) unless you have a Tacoma that would need a driver's side diff...
also check the side of the third, stock mini trucks are 8", the Land cruisers used a larger third if I recall correctly...
I would recommend that you inspect that axle closely before purchase. I lived in NY for 5 years and remember what the east coast salt did to axles....
--If it turns out to be one from an 84-85 Toyota (last one pictured) it the one to get...
examples of Toyota front axles and measurements:
Toyota Mini Truck Front Axle Identification
79-80 no gusset
81-83 short gusset (to u-bolts)
84-85 long gusset (past u-bolts)
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, SA Hubs
ID Toyota Mini Truck axles
79-80 no gusset
and if you get it is it will more than likely need to be rebuilt:
Rebuilding Front Straight Axle:
http://www.birfield.com/~morgan/tech/axle/
http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
http://www.lukemiller.org/toys/1985_...t_axle_FSM.pdf
Rebuilding Aisin Manual Hubs:
https://www.yotatech.com/forums/f116...ferrerid=12218
79-80 no gusset
79-80 no gusset
:wabbit2:
jerusry
10-19-2015 05:28 PM
