First Mods
Old 04-05-2010, 06:39 PM
RSH1's Avatar
First Mods
I am new to the mod side of Toyotas. I've driven them for about ten years but now have the time and money to start investing into them.
I just got a 98 SR5 4Runner and would like to remove the running boards (rusted) and install new mudflaps. I would eventually like to also install new fender flares if I can find the right ones.
Basically I am looking for insight into the (1) steps of removal and things to be careful of, (2) replacement flaps and (3) ideas on flares.
Any input is much appreciated.
Old 04-06-2010, 06:33 AM
Yota Yeti's Avatar
Welcome to YotaTech!
I have a 97 T4R Limited and the running boards are pretty simple. They are a basic bolt on assembly. I used a little WD40 on the bolts first, others used something like liquid wrench since the bolts are rusty, then unbolt the connection. I think there are 6 bolts per side.
Sorry cant help with the others.
Old 04-06-2010, 06:40 AM
Yota Yeti's Avatar
since you will be under the truck, throw on some safety glasses. Dirt and whatever else will fall on your face. Just makes it easier IMO.
Old 04-06-2010, 12:06 PM
brian2sun's Avatar
The rb removal is very simple, just look at it and it's self-explainitory. Here's another recent thread about the flares..
http://www.toyota-4runner.org/3rd-ge...my-flares.html
Old 04-08-2010, 01:56 PM
RSH1's Avatar
Found the parts for the mud guards
I found the parts for the mud guards at www.toyotapartszone.com they should arrive any day now. I'm getting excited.
Next step...
I've got two ten inch subs and amp from an old rig I'm hoping to put in the back without limiting cargo room. I'd also like to add some 6x9's to it too.
Old 04-10-2010, 02:38 AM
Ron Helmuth's Avatar
before you scrape your knuckles consider reading this thread about broken bolts
https://www.yotatech.com/forums/f2/broken-bolts-24590/
I was impressed with the posting regarding a 1 to 1 mix of acetone and Auto Tranny Fluid to achieve better results for penetrating rusty bolts to break them free.
air tools with heavy duty sockets will be an immense help if those running boards are rusted on there and most are....
welcome to this fine forum
Old 04-11-2010, 09:27 PM
RSH1's Avatar
Thanks for the heads up, I'll be sure to do that.
Old 04-12-2010, 05:27 PM
good luck sir
Old 04-12-2010, 05:45 PM
Blue_petersen77's Avatar
definately! I had all kinds of garbage falling on my face.... In hindsight I would have worn a bandana or something over my mouth and nose too. Stuff falling off running boards mixed with PB blaster isn't as tasty as you'd think lol
Old 08-12-2010, 08:10 PM
RSH1's Avatar
This post is late in the making but I thought better late than never.
I did use the mix of acetone and tranny fluid and will say it really did the trick. I also have pneumatic tools so taking the running boards off wasn't really all that bad. I did, however, have a little trouble lining up the OEM SR5 mud flaps. I had to use some 1/4 inch self-tapping screws to get them to stay where I wanted rather than the black plastic screws from Toyota.
I also installed the subs and was ready to do the lift, but got a killer offer and made some money on the 4Runner. So I bought a 98 Tacoma ... back to the drawing board.
Old 08-12-2010, 08:46 PM
myyota's Avatar
Were in Idaho are you located ?.
Old 08-12-2010, 09:35 PM
RSH1's Avatar
Idaho Falls
Old 09-12-2010, 10:03 AM
b5280's Avatar
I have found several postings including instructions for removing running boards on a 3rd generation 4runner limited (2000 black and gold 2-tone). most have had pictures that are no longer viewable. anyone have a favorite posting that has good pictures before and after including the required replacement parts list? thanks
TheBFA
02-15-2020 06:55 AM
punks_is_4x4
05-31-2016 06:03 AM
voiddweller
53
02-01-2016 05:46 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
Quick Reply: First Mods
