engines missing after hitting a huge puddle of water
Old 01-12-2006, 10:23 AM
punkindrublic721's Avatar
Question engines missing after hitting a huge puddle of water
ok last night i was on my way home and was haulin ass and it was hella dark and i hit this huge puddle and about 2 minutes afterwards my truck started missing really bad.. it has no power.. takes forever to get to speed and its missing and wants to die when i come to a stop cause the rpms are really low... anyone got any ideas? im stumped.. distributor is dry spark plugs dry air filters dry.. please help
1991 Toyota 4x4/ 22RE
Old 01-12-2006, 11:08 AM
eric-the-red's Avatar
Something probably got wet, check the wiring connections on the engine. The ignitor, coil, afm/maf, etc. Pull the connectors apart and spray some WD-40 in them. That should get the water out.
Of course there's also a slight chance that it's totally coincidental, but highly unlikely.
Oh, and one hint for future posts, year, model, engine type would be useful info
And stop using coloured fonts, green doesn't show up very well for those of us with older eyes
Old 01-12-2006, 12:03 PM
ok ill try that and see if that helps. thanks
Old 01-12-2006, 12:43 PM
Glenn's Avatar
It's likely your alternator got a dose of water. It happens to me every once in a while. Less likely is your distributor got wet, but since it's a lot higher, it's not as likely to get soaked. It's usually a temporary situation.
Old 01-12-2006, 12:53 PM
you think that would make my truck miss and not have any power? i dont think so... i can floor it and it bogs and misses bad... i have a small hill by my house and i had to have it in second gear half throttle to make it up haha... when i floor it, it just misses and cuts out etc... so i dont think its the alternator
Old 01-12-2006, 01:10 PM
Glenn's Avatar
Yeah, I think it is the alternator getting wet. I don't know why it makes it bog down and miss. I think the water grounds the current for a second or so, keeping it from getting to the rest of the ignition. It is definitely electrical related. Mine does the same thing you are describing--falls on its face for a second or so. If you don't think it's the alternator, what do you think it is? The alternator is the lowest part of the electrical system that I can think of.
Old 01-12-2006, 01:14 PM
not sure.. but this happened 2 days ago.. all day yesterday drivin it to work cause i aint got another vehicle it ran like crap and its still doing it.. 3rd day and still doin it.. last year it did this and after a few days it ran fine again
Old 01-12-2006, 01:37 PM
Glenn's Avatar
Yeah...gotta dry things out a little and it will be fine. Spray the inside of your distributor cap with WD-40. The WD on that stands for Water Displacer.
Another thing that is possible is that the insulation on your plug wires could be cracked. These cracks allow moisture and dirt to short the current before it reaches your plugs. It doesn't even have to be raining/wet outside for this to be a problem. High humidity can create these problems. Do you have any idea how old your plug wires are? They might need to be replaced.
Old 01-12-2006, 01:40 PM
they arent that old at all.. and yeah ive checked the distributor cap.. its bone dry under that thing
Old 01-13-2006, 08:43 AM
4Runner911's Avatar
Uhh... surprised no one has mentioned this, but you may have inducted a large amount of water in the air intake. If it made its way into the cylinders, it's time for a new motor. Water does not compress, and results in engine damage. I'd do a compression check. My son's friend just had this happen in his Honda. Lots of rain here lately, and he drove through a good-sized puddle of standing water.
Old 01-13-2006, 09:51 AM
no i didnt hydrolock my motor.. i talked to a buddy and i checked my check engine light codes and its sayin my intake air temp sensor signal number 24 and 31 my air flow meter...m gettin ready to check it here in a few... so thats where i stand
Old 01-20-2006, 12:14 PM
surf4runner's Avatar
"engines missing after hitting a huge puddle of water"
from this i thought maybe it had fallen out and dissolved or something
Old 01-20-2006, 09:21 PM
PirateFins's Avatar
I had the same exact problem. Wait until it is dark and open the hood. Take a look at all of your spark plug wires and distributer cap. Rev the engine up and look for spark/arcs. I had 2 wires that were bad and were arcing to the valve cover causing the miss. It was worse on days that it rained, but came on all of a sudden after hitting that puddle. Check it out.
Old 01-21-2006, 12:01 AM
marko3xl3's Avatar
You could also check the connection to the AFM. Does it stay alive at idle?
Old 01-24-2006, 01:09 PM
well about a week ago i took off my air flow meter and tested it with my ohm meter.. 2 of the connections werent reading right.. so i went to the wrecking yard and got one for 40 bucks.. looks like brand new.. new they wanted $600 something bucks... now my truck runs great... thanks for the advice...
icentropy
09-16-2020 02:47 PM
cyclist231
07-07-2015 12:56 PM
skoti89
07-06-2015 07:45 PM
karbin
07-05-2015 11:37 PM
Quick Reply: engines missing after hitting a huge puddle of water
