Drop bracket and Ball Joint spacer pics.
Anyone have any pics of a 86-88 with a 4 inch drop bracket and ball joint spacers? Im thinking of doing that to my 87 just trying to get some ideas. Possibly a 32-33 inch tire. Any info would be awesome, lift brand, gears, tire size, etc.
Might try SDORI's site, as I think Frank has a 4" bracket lift and spacers on his 2nd gen:
Although he only installed them for added travel and backed off his torsion bars and so saw no net lift with the spacers:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ4
OMG. You don't even need BJ spacers to clear 33 12.50's technically, let alone a 4" bracket lift. Stupid lift sites telling people to slap a 4" kit on a truck to fit 33's should be considered false advertisement.
A little trimming and/or hammering on the pinch welds on the fender, a fw cranks on the torsion bars, the proper backspacing on the wheels and maybe a tweak of the valence support brackets and your golden.
4" bracket lift will clear 35's EASY.
With that said, the ride is a tad harsh and you loose some down travel by cranking the torsions to fit the 33's. Use the ball joint spacers if you mind a harsh ride. But by no means do you have to spend $800+ on a lift to clear 33'.
31's will fit with absolutely no modifications whatsoever.
Thanks for the link, im still trying to decide exactly what i want to do for sure. This is my first 4x4 truck and im going on a college budget so its kinda tough to figure out what i want and be satisfied.
There is some tire fitment information below (it is likely linked off of the link above):
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
