driving without rear driveshaft
is it okay? i just snapped a u bolt and i want to drive it home to fix it. so i figured i could just remove rear shaft completely and drive it in 4 wheel drive home. i just want to make sure with all you before because i dont want to break anything even more.
thanks all you rock!
My dads had a catastrophic failure of his u-joint where the drive shaft came off while driving. He has driven it around for a week or so with his removed and it has been ok.(hes got a junk yard driveshaft and having it balanced and both u-joints replaced) So you are fine to get home on it
I presume leaf spring u-bolt? Because the u-joints don't have u-bolts.
So you're trying to remove the driveline input, and make the rear end just a trailing unit, not a drive unit? It may be fine, very slow speeds would be my recommendation. Or maybe a section of all-thread and hardware to act as a roadside temp repair if it worries you?
u-joint or u-bolt? if it's the u-joint then yes, you could disconnect the rear d-shaft and drive in fwd/4wd to get you home. if it's a rear u-bolt which holds your axle and leaf springs together, i dunno if i'd personally risk this one depending on how far/type of road you have to take it on. If the 2nd u-bolt is ok (and the other 2 on the opposite side of axle are good) I'd at least toss a ratchet strap or 20 wraps of bailing wire on there to get home if i was to attempt it.
Yes, you can if you remove the rear driveshaft. Basically you'd be in front wheel drive mode. Assuming you mean the u-bolt on the rear of the driveshaft It's not going to hurt anything.
He means U-joint, that's why he's removing the drive shaft. Yep, agree, OK to drive on front wheel drive with drive shaft removed to get you home - not all winter - LOL!
It'll be fine as long as your nor running the Baja 1000 or drag racing.
All the power will be going thru the front drive components which normally don't have that much power applied to them so take it easy and you'll be alright.
I drove my 87 for several months incl some winter with no rear driveshaft all over the place... hwy/city no issues at all even dirt lots at construction sites... it drives like any other large FWD [think dodge caravan] just don't load the back up too heavy or you might find some traction issues...
Drive it as long as you like without the rear shaft, it will be fine. The front axle isn't made of glass.
To think you will break something in the axle is the same as people who think 4wd has a speed limit.
Was more thinking of the transfer case applying all the power thru the chain to the front instead of passing it straight thru to the rear drive line myself.
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
skoti89
07-06-2015 07:45 PM
Jnkml
07-06-2015 01:20 PM
