Drivin' a turd
Old 04-02-2012, 04:02 PM
Tonkatruck's Avatar
Drivin' a turd
I have a 1991 pickup up with the stock v6 3.0. I recently put some 33" BFG all terrains on it and now i notice the lack of horse power and mpgs...what can i do to improve my mpgs and hp??
Old 04-02-2012, 04:21 PM
James Woods's Avatar
Put in some different gears
yotarover's Avatar
go back to 28's or 29's. change the gearing run nos
Old 04-02-2012, 04:53 PM
ThatGuy1295's Avatar
Case closed
Old 04-02-2012, 05:00 PM
Junkers88's Avatar
Change the gearing and/or font size!
Really though you could probably do a search and get the answers you need....
Old 04-02-2012, 05:03 PM
yotarover's Avatar
check engnbldr get another head or have yours machined, change the gears front and rear, add a sneaky pete bottle of noz . when you have to go up hills hit go baby go. and dont forget the exhaust side.
Old 04-02-2012, 06:28 PM
94toy22re's Avatar
Start with a 30hp ebay chip, a electric supercharger and a tornado fillter. After all that should be equal to a corvette in 0-60. You can either swap in new gears or put the smaller tires back on.
Old 04-02-2012, 08:44 PM
Discombobulated's Avatar
Put 35's on it.
Old 04-02-2012, 09:03 PM
ZeroHour's Avatar
I couldn't decide wether to cry or choke with laughter after reading that.
Like pretty much everyone suggests, gears. You could aim for some cold air intake setup and sure the dramatic head work, but the easiest thing that would give you the most results would be gearing, because that 3.0 is not going to spin those tires no matter what you do, unless you're in 4L without the front hubs locked
Old 04-02-2012, 09:10 PM
BoredOutnJackdUp's Avatar
Thats not true. My 22re smokes my 33s all day booooooyyyy!
Man everyone is just too quick with the sarcasm!
not even giving me a chance
btw You could swap in a pruis motor and get a coffe can muffler
Old 04-02-2012, 09:45 PM
ZeroHour's Avatar
Depending on the gearing, and maybe if he has a 5spd and dumps the clutch I could see it, otherwise, my experiences, no. /notsarcasm
Old 04-02-2012, 10:10 PM
goodyota's Avatar
make sure the engine is tip top and check it for codes. if a 4 cyl can handle 33's ur v6 probly needs a little tuning/sensor replacement. my 2 cents.
Old 04-02-2012, 10:15 PM
Leviticus6432's Avatar
a simple tuneup might add a few ponies... my 4runner had 31s stock and ran rough. I got used to the slowness in no time... eventually I swapped to 33s and did a tuneup at the same time. Felt exactly as fast as before lol. A valve job was included in the "tuneup"
Old 04-02-2012, 10:19 PM
ryan9376's Avatar
Scrap the 3.junk and buy a 22 r or swap with it for a v8.
Old 04-03-2012, 04:31 AM
Levinz11's Avatar
Old 04-03-2012, 05:18 AM
Jkelley429's Avatar
and don't forget, just adding a sticker that says SUPERCHARGED adds 20 hp.
Old 04-03-2012, 08:06 AM
93Xtra-Cab's Avatar
Check to see if your muffler bearing needs replacin'. If that don't work, it's totaled.
Old 04-03-2012, 09:22 AM
bob200587's Avatar
POoP ThReAD!
Old 04-04-2012, 08:07 PM
hahaa the good old muffler bearing.
Big Little Bear
230
11-13-2023 11:42 AM
dropzone
1097
07-17-2022 04:28 PM
BADLNDS
05-12-2005 10:03 AM
runnerboy97
10
09-02-2003 02:49 AM
Quick Reply: Drivin' a turd
