Driveshaft for SAS question
Old 12-15-2009, 08:07 AM
jamarak's Avatar
I see that the Driveshaft for the front on a SAS needs lenghten. But all the kits I see say you can not drive on the street above 50mph. Where do you get one that can be driven on the road daily?
Old 12-15-2009, 08:13 AM
4Crawler's Avatar
That only refers to using 4WD (or front wheel drive) at that speed. In 2WD the type of driveshaft does not matter as it is not turning. All has to do with how tight the shaft is, how well balanced it is and how correct the front driveshaft angles are:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
I had a front shaft built from off-the-shelf parts at a local driveline shop that works quite well at speed. It uses the longest travel Spicer or Neapco slip yoke in the catalog and works quite well. I am a few degrees off on my front angles so there is a little vibration at high speed, but not bad.
Old 12-15-2009, 09:17 AM
jamarak's Avatar
So i guess the trail gear would work then. I didn't even think about that. Thanks. If anyone else has any ideas or comments please feel free to share them with me. I hope to start the SAS after the first of the year. Axle will be here in a few days!!!!!
Old 12-15-2009, 09:28 AM
toyoffroada's Avatar
one option is after you get done with the sas measure the length the driveshaft needs to be at full droop and at full compression, then call steve at southbay driveline(google),, it is sure not the cheapest way to go but it will be balanced,,, I went with the four inch TG in the ft. and he made me a long spline double cardin shaft that works great,, no vibe at all,,,,,,
edit to say also lay a straight edge in between the transfer case flange and diff. flange and get a angle guage so you can tell him the max angle at full droop,,,, ,,, also the tg long spline kit will also work a lot cheaper,,,,, I just didnt want any vibes going on.,,,, my ft. was around five bills but worth every bit of it....
Flying91
45
04-11-2024 04:39 PM
4x4-runner
04-18-2017 09:08 PM
mussy01
12-13-2016 08:20 PM
Tonetrk
08-06-2015 10:06 AM
Sr5crawler
07-31-2015 12:32 PM
Quick Reply: Driveshaft for SAS question
