Double Cardan Trouble
Old 12-11-2012, 10:12 PM
dallen006's Avatar
need all info on double cardan joints u can give. Center of my joint was rusted and broke off i think. I just got this 97 toyota tacoma in June. a guy at the shop said the part needed to be made and ordered special because toyota didnt make replacement parts for it. how to i fix this or is there a cheaper way.
Old 12-12-2012, 01:23 AM
bobcat86's Avatar
There shouldn't be any need for that part to be made. I just went through this process last night on a customers Jeep and I got the part from a driveline shop, so that would be where I'd suggest ya start first. The part cost less then 40$ and didn't take too long to swap out. If you plan on tackling it yourself, you'll need a vise, a pair of sockets and needle nose pliers. If your unfamilliar with changing u joints, pm me and i can walk ta through it. Hope this helps.
Old 12-12-2012, 05:30 AM
waskillywabbit's Avatar
Didn't make replacements for it. Right.
Wanna buy ocean front property in Arizona?
:wabbit2:
Old 12-12-2012, 06:03 AM
MudHippy's Avatar
Not that there aren't ways of replacing the double cardan(with one that will work just as good as stock), but Toyota will only sell you a replacement as part of an entire Propeller Shaft Assembly(w/ Center Bearing). And will not sell you any parts for a double cardan, AFAIK. The prop shaft assembly is ~$1036.
kawazx636
10-06-2021 03:03 PM
voiddweller
10-02-2015 07:47 AM
Matthew Perez
09-28-2015 05:43 PM
Ilovemountains
09-15-2015 04:17 AM
128keaton
09-03-2015 05:09 PM
Quick Reply: Double Cardan Trouble
