Daily driving with dual transfer cases?
Old 09-07-2010, 06:42 PM
Canadian78's Avatar
Looking at buying a toyota with dual cases. Just wondering how it would be daily driving it.
Old 09-07-2010, 07:25 PM
toyotasaurus's Avatar
I lost about 2mpg, but other than that have had zero problems with mine.
Old 09-07-2010, 07:27 PM
myyota's Avatar
It shouldn`t be a problem at all as a daily driver.
Old 09-07-2010, 07:29 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I'd imagine slow, if you used low range...
Old 09-07-2010, 08:21 PM
scuba's Avatar
Old 09-07-2010, 08:28 PM
Fossilized
Staff
dropzone's Avatar
if they are set up properly it should not be an issue...you will notice some more gear noise and the duals seem to generate more heat...
Old 09-07-2010, 08:49 PM
85gijunk4x4's Avatar
Originally Posted by tried4x2signn
i'd imagine slow, if you used low range...
hahahaha lol!!!!
Old 09-08-2010, 04:59 AM
waskillywabbit's Avatar
Lots of things you can do you should not do.
Mine were hot and noisy and at high speeds blow oil out the breather and make a mess.
I would not have duals in a daily driver personally.
Old 09-08-2010, 06:14 AM
muddpigg's Avatar
Drive mine everyday. I'd test drive the rig really well if its not set up right it'll let you know.
Old 09-08-2010, 06:37 AM
4Crawler's Avatar
My '85 dual case 4Runner gets DD much of the time and no issues with noise or oil fumes for the most part. I do get a little more heat from them on high speed runs and in just the right conditions of cross wind and speed, I will occasionally get a whiff of gear oil in the cab, but once I finish venting the cases up into the engine compartment, that should be a non-issue.
I use the 2L gear range all the time, though. Handy for parking or getting in and out of tight spots or in stop-n-go traffic.
Old 09-08-2010, 06:11 PM
id hate to invade the op's thread, but this could help me and the op.
but how about daily driving witha marlin crawler twin stick?
Old 09-08-2010, 06:16 PM
AxleIke's Avatar
I have no issues with dual cases other than a bit more noise. I don't blow any oil out. I never had issues with heat. Things are warmer after the drive train lift, but that's not surprising due to the fact the cases sit right next to me in the cab now.
I'd say its fine. Its not going to be a Cadillac on the road, but I assume you know that.
AxleIke's Avatar
Not sure why that would make a difference. I dd mine. Its fine.
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
skoti89
07-06-2015 07:45 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Daily driving with dual transfer cases?
