coolant temp sensor
Old 09-03-2013, 07:44 PM
4Crawler's Avatar
Originally Posted by cummo85
what should a 2.8L diesel non turbo run at?
my 85 4runner runs at 90 degrees in winter around town, is that too hot?
Not familiar with that exact engine, but the 22RE runs an 88C t-stat:
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
So a bit over that temperature is probably what the engine should run at since the t-stat is what controls the engine temp. So either pull the t-stat and see what temperature is stamped on it, but that sounds like a decent running temp.
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Poncho0206
07-10-2015 06:21 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: coolant temp sensor
