coolant sensor problems!
Old 12-17-2011, 04:17 PM
shumaker86's Avatar
ok so i have a 1986 toyota pickup 22re sr5, there are two sensors on the intake, one i know is the coolant temp sender, but there is one next to it that looks exactly the same just bigger. i know its not the coolant temp gauge. it has a 2 wire plug in. any help?
Old 12-17-2011, 05:10 PM
Sensei's Avatar
Welcome to YotaTech... If you are talking about the two sensors in the manifold under the thermostat housing then the one to the left is the cold start injector timer switch. The housing at the connector I believe is brown.
Old 12-17-2011, 08:12 PM
shumaker86's Avatar
alright thank you, its what i thought just couldnt get any confirmation.
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
07-16-2015 06:20 AM
Poncho0206
07-10-2015 06:21 PM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: coolant sensor problems!
