Convert Drum brakes to Disk brakes??????
Old 05-06-2010, 06:16 PM
Bojangles's Avatar
1994 Toyota Pickup 4x4 22re 4cyl
Is this even possible? I want to put Disk Brakes all the way around on my yota, but i dont know if this is even possible seeing as that i have Drum Brakes. If it is i would love to do it, but i need some information and some help. How about it yall?
Old 05-06-2010, 06:48 PM
yayfortrees's Avatar
Anything within reason is possible with enough time and money. The question is, why bother?
There is not a lot of braking power available from the rear wheels, so converting to disc brakes isn't going to provide much, if any added performance.
On top of that, you would have to use calipers with a parking brake feature, unless you want to do away with your parking brake. (Something that isn't really advisable.)
My suggestion, find something else to put your money towards.
Old 05-06-2010, 06:50 PM
Bojangles's Avatar
Well the only reason i would want to do this is because i hate brake drums lol Disk brakes are so much easier to work with My dad asked me to get on here and ask someone about it, see what yall thought.
Old 05-06-2010, 06:52 PM
BigBluePile's Avatar
geeezus. DO A SEARCH.
Yes you can.
Old 05-06-2010, 09:21 PM
85TurboRunner's Avatar
Here let me spoon feed you.
http://www.sky-manufacturing.com/new...uct.php?id=128
this too.
https://www.yotatech.com/forums/f116...riteup-121582/
This isn't the only kit out there but its a start.
Old 05-06-2010, 09:23 PM
Old 05-06-2010, 09:24 PM
Fossilized
Staff
dropzone's Avatar
wow, yes it can be done...
trail gear has a kit: http://www.trail-gear.com/brakes but you need a line lock to use for an ebrake.
or if you don't go with the line lock use a transfer case e brake kit like this one:
http://www.sky-manufacturing.com/new...uct.php?id=142
sky's makes a kit ( i have one, just need to install) http://www.sky-manufacturing.com/new...uct.php?id=128
might want to do some research using this link
Old 05-06-2010, 09:25 PM
camo31_10.50's Avatar
yep..actually quite simple...FROR makes a full floater kit and it's a GREAT upgrade over sky's kit...with sky's kit you mount the disc to the axle it'self (i believe) and with FROR (front range offroad) you mount the kit to the Axle housing...which means it won't vibrate as much...although idk how much sky's kit vibrates LOL
i'm going to be doing the full floater conversion and disc brake conversion with some celica supra calipers to retain my e-brake.
Old 05-07-2010, 12:06 AM
drew303's Avatar
No it can't be done. Thats such a stupid idea.
https://www.yotatech.com/forums/f116.../#post50586263
Old 05-07-2010, 07:45 AM
Bojangles's Avatar
Alright thanks, ill look this stuff up.
Old 05-07-2010, 08:53 AM
well, good 'cause we were all worried...
Old 08-12-2010, 10:01 AM
twistedsymphony's Avatar
this too.
thanks for the links!... I just searched and this was the first thread that came up actually related to the topic... that tutorial wasn't even listed in the first 4 pages of results
Old 01-07-2011, 02:06 PM
RT1991's Avatar
allpro offroad has complet kits if you wanna dish out the cash, the plus side is that everythings there!
http://www.allprooffroad.com/pickupbrakeupgrades
09-04-2015 09:27 AM
Scatterbrain
14
08-31-2015 06:26 AM
SharpStick
08-29-2015 12:59 PM
JHalcyonM
08-04-2015 01:19 PM
CanRunner
07-20-2015 01:29 PM
Quick Reply: Convert Drum brakes to Disk brakes??????
