Old 02-09-2016, 10:11 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
check engine light
Old 08-26-2016, 04:59 PM
osv
osv's Avatar
Originally Posted by t-rav
when i unplugged it, it still past smog!!
dumb thread brought back to life, lol... why?
if the check engine light isn't visible when the ignition switch is turned on, before the engine is started, i would imagine that the smog tech would fail the car immediately.
Old 08-27-2016, 12:06 PM
Larry H's Avatar
Can anyone help have check engine light on 1993 Toyota 22re tried jumping pins TE! and E1 blinks constant, hooked up scanner says no communication how can I check to make sure ports are okay ? is one of this connections hot and 1 is ground if so which one is which
Old 08-27-2016, 12:20 PM
osv
osv's Avatar
Originally Posted by Larry H
1993 Toyota 22re hooked up scanner
http://www.4crawler.com/4x4/CheapTricks/TroubleCodes/
Old 09-01-2016, 05:53 PM
jhuggz2502's Avatar
Sad Day
Hey guys so ive had my 1993 pickup for almost 3 years now and put nearly 30k on it. No problems ever with it until one day when i was on my way back from lake tahoe. Drove probably about 1500 miles all together the drives were about 400-450 at a time, on my way hear just an hour or so out my check engine light comes on... Wasnt starting so i got a new battery and alternator cuz the triple A person showed me my alternator was going for ~13 all the way down to 5.5 then creeping back up to where its supposed to be. Either way got all that taken care of but the light is still on...
Here's my question:
Used a wire to get the code but its really confusing how to tell which code is which. It flashes once then once again with only a short pause between then a pause about 3-5 seconds then flashes again. Then repeats this over and over. Any idea which code this is? Its a 1993 toyota pickup 3.0 v6.
Thanks in advance for your time!
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: check engine light
