cheap tricks for newbies
Old 02-04-2011, 08:34 PM
jjearl's Avatar
I am building a 1989 4runner 2 door up from scratch. have $500 to play around with, i know that if you remove the headlight switch wiring and wire it into a relay, that makes your headlights brighter. and that you can take chevy leafs and flip the frame mounts for a lift. but what other random/cool tricks are floating around here? i have the the 3.slo by the way. any cheap performance mods u know?
Old 02-04-2011, 08:54 PM
myyota's Avatar
I think you have your information wrong, You don`t remove the head light switch wiring, there is a wiring harness with relays that you can add that helps boost the voltage going to the head lights. Check out 4crawlers web site, he has a write up on how to do it. When you add chevy springs you don`t flip any of the frame mounts for a lift, you need to buy a shackle and hanger kit, cut off the mounts for the stock springs and welld the mounts on for the chevy springs.
Old 02-04-2011, 09:04 PM
BoredOutnJackdUp's Avatar
weld the diffs, stuff some cheap meats and use the other
200 bucks for gas money in wheeling
Old 02-04-2011, 09:12 PM
jjearl's Avatar
cant weild the diffs. guna be a dailey driver. and i need to find a way to get my trucky lifted cus my rear leafs are flat. i live in bc and wana keep it legal
Old 02-04-2011, 09:23 PM
lockrite rear? zuk mod, and semi aggressive treads.
Lifts shouldn't be the first priority.
of course you will get that from everyone on here
There is the motto only lift as much as you need to.
Old 02-04-2011, 09:36 PM
jjearl's Avatar
you don't understand though... my rear leafs are flat, the whole truck sags. hahaha. need a legal way to bring back up to stock height to match front. will get resprung if need be. but any other chearper ways would be nice too
Old 02-04-2011, 09:42 PM
You could always pull some stock ones from a junk yard that aren't.
But the chevy springs will lift the rear end a good 3-4 inches over stock?
and then you will have a problem leveling the front unless your gonna
use a bracket lift or BJ spacers?
Pics of your flat springs?
Old 02-04-2011, 09:44 PM
jjearl's Avatar
cant crank the tortions and put wheel spacers?
Old 02-04-2011, 09:48 PM
camo31_10.50's Avatar
rofl wheel spacers aren't going to do ANYTHING to lift your truck bahahahaha
if you go with 63" chevy springs in the rear, then you'll want a bracket lift up front.
a bracket lift in the front, with 63's in the rear will be almost perfectly matched, should be a TAD high in the rear.
Old 02-04-2011, 09:50 PM
jjearl's Avatar
i have ifs....
Old 02-04-2011, 09:51 PM
Birdbrain's Avatar
i have ifs....
Your killing me smalls...
Bracket lift is for lifting IFS...
Old 02-04-2011, 09:52 PM
jjearl's Avatar
go easy on me. just learning truck language hahaha. im 16
Old 02-04-2011, 09:53 PM
oh boy.
were getting out of the $500 range with just the bracket lift.
and i don't know why the wheel spacers are necessary?
How about we just buy a $500 k5 blazer and swap everything on to the frame?
Old 02-04-2011, 09:54 PM
Birdbrain's Avatar
its called the search function and google. Start reading, welcome to being a big boy, things aren't handed to you anymore.
Old 02-04-2011, 09:55 PM
jjearl's Avatar
i was saying. if cranking tortions 4 inches was an option. the front wheel base would be shorter due to the SLA function found in IFS. but i know tortions only lift 2 inches and no more
We've all been there. and i myself know oh too well about the cruelty of some members on here.
(not saying anyone is being out of line right now!)
But i know the search tool saying has been beat to death.
But seriously the best advice i ever received was
Old 02-04-2011, 09:56 PM
But the last one bird brain was a little rude.
Old 02-04-2011, 09:58 PM
jjearl's Avatar
the reason i joined yota tech was cuz every google search i did, the first 5 results were yotatech, every time... so why not make an account and interact lol
Old 02-04-2011, 09:59 PM
Makes sense.
But the guys on here will eat you alive haha.
There is a yotatech search box as well.
Old 02-04-2011, 10:01 PM
jjearl's Avatar
yeah. i dont remember seeing one dedicated to little tricks and cool things you can do. like, did you know the fuel pump can be accessed by lifting up the rear passenger seat and unscrewing the panel. saves a load of time
Quick Reply: cheap tricks for newbies
