changed to bigger tires now truck squeaks
changed my tires to bf mt's now my truck squeaks loud..thought it was my lugs(has washers on it)..but changed those out and its still makes noise
ideas on what it is and how to fix it?
thanks
thanks
Sponsor
have you tried going poop??
changing you tires shouldnt cause anything to squeek.. unless your tires are rubbing you UCA.
where does it sounds like its coming from.. front, rear, top, bottom, middle, center, right, left, aft, bow, starboard, port, inner, outter, driver, passenger?
can you get it do it at low speeds and have a buddy run besides to more closely inpoint the location?
have you looked under the truck to see if you can see anything? felt around feeling ubolts, lug nuts, ball joints, uca/lca bushings, shock mounts... making sure everything is tight..
posting the limited details that you have is like going to a medical forum and saying my tummy hurts. how can i fix it...... re read this post and it'll make more sense the 2nd time.
.....what are you driving. very specific. what size tires, and did you change size when you changed brands. with the information we have, my only diagnosis is that someone used a mouse instead of a wheel weight during installation.
Kick it! That works too. Maybe it's the new rubber?? BTW, my Runner squeaks also. i just checked if everything was tight and just let it be.
-big blue, crimson yota...my parents live in OH. I'm always up there, seven miles from NAs, nice to see local YOTA's
sorry guys..i logged in from face book but it doesnt work too good so i made an account direct..
i have a 924runner went from 31x8's(i think michelins) to 31x10 1/2 bf mt's
sound is coming from front and its some where near the tires
it only does this in lower speeds i'd say up to 30 then its smooth and well the are loud so it might be a rattle
thought it was my lug nuts at first(had washers on them) so i changed it..still wasnt the problem then i noticed my idler arm was toasted and thought maybe that was the problem but changed it and still makes noise..
a lotta people are telling me theirs do too but my dumb @$$ neigbors complain..
thanks for all the input guys!
my guess is the dust cover got bent and is rubbing on the rotor when installing the wheels back on. could be just a rock in there as well. happens to me all the time when I go off-roading.
it happens on the flatest of grounds from 10-20mph nd when i start to slow down and im thinking its a rattle.. i'll take off my tires tomorrow to have a better look. thanks guys really good suggestions lets see what the deal is tomorrow
Aleeex_u
06-05-2016 06:52 PM
nrgetic99
07-10-2002 07:39 AM
