Cant find detailed EGR removal guide.
I have serched for about an hour now and have come across this same question but no answers. Plenty of oppions and alot of good reading but still yet no good play by play guides to removeing the EGR in a 22re. I know it is supper basic but is there any one that can point me in the right direction please.
Where is the triangle blockoff go? Any pictures with highlights to every thing remove... really soda can will work? Know it must be supper simple just turning still that's all
LC Engineering make a block off kit for removing the EGR. Its easy to do, just remove the EGR and install the block off plates in it place and plug the vacuum line.
I traced the egr outline onto a steel electrical cover plate then cut it out with an angle grinder. After that just used the original bolts to screw it on to the head. Assuming that you're using an after market carb, then just remove most of the vacuum lines and plug the outlets
dude that electrical cover idea is great, never though of that. gonna have to keep that in mind when I decide to finally clean up my hack of a weber install. lol.
jerusry
10-19-2015 05:28 PM
