birfield joint
birfield joint
heyy ya'll, got a quick little question for ya'll. If any of yall are familiar with the strait axle birfield joint, and have ever noticed differential coming from the joint itself, what needs to be replaced? I looked and looked over it and its not broke or cracked. any advice?
sounds like he;s leaking differential fluid from the birf? I know nothing about these other then were to find rebuild parts, so I don't know if that's even possible? I know they are supposed to get greased beyond belief right?
Bhahahahaha Are you kidding me?
I think he's just not familiar with Jibberish. Ain't nobody on here more knowledgeable on SAS/SFA then wabbit.
If you have a differential coming from out of the birf you got serious issues as I don't even think a differential would even fit down the axle tube to begin with. If it came loose you'd probably run it over with the back tires before it came out the birf.
After that remark, I'd e surprised if he even replies.
see im all new to toyota and just getting familar with they're parts, ive heard alot of people say its a damn good joint, but i think its a seal somewhere around the joint itself thats causing it to leak.... idk
I'ma go ahead and agree with wabbit, you should replace the inner axle seal and if you're gunna tear it apart that far, you may as well rebuild the whole thing.
Solid Axle Rebuild Guide
Wabbit's link to the FSM is also your friend. You will need a brass punch to deal with the cone washers, best price on them I have found is at NAPA Auto.
hey SCToy, thanks for the thread, it really helped me alot, I'll keep ya'll up to date on how it goes, im gonna order the trail gear knuckle rebuild kit and just rebuild the whole thing
im still learning about these trucks. Ive been born and raised around ford's. Bought my first yota about a month and a half ago and it go me hooked.
Last edited by dropzone; 09-09-2011 at 12:42 AM. Reason: pic link is bad, tried to fix it
I tried to fix your pic link, but it was a no go.
you can't just copy and paste a file name from your drive.
upload your pics to a free hosting service like photobucket.com
than copy and paste the [img] code (it will be just to the right or below your pic as you scroll over the thumbnail in your photobucket album)
