backspacing-fender flare fit?
Old 03-08-2014, 09:04 PM
Waylayer's Avatar
Want to push out tires without using 2-3" wheel spacers. Have 3" fender flares and no longer running 33x12.5's. From the searches and getting back spaced on back spacing I think I would need around 6" back spacing, but what I have now and other wheels are about 4". Would it better to go with a smaller spacer and little wider tire then to compensate with back spacing. not sure of any where that sells cheaper steel wheels with lots of back spacing.
Old 03-08-2014, 09:11 PM
scuba's Avatar
You need to decrease the back spacing if you want to push the tires out.
If you have 4" BS try 2.5"-3" back spacing.
Old 03-10-2014, 05:25 AM
Waylayer's Avatar
Less space between back of wheel and lug holes with less back spacing meaning tire mounting surface is pushed out from hub.
Old 03-10-2014, 07:03 AM
93Xtra-Cab's Avatar
Why don't you just take the fender flares off?
Old 03-10-2014, 08:04 AM
Waylayer's Avatar
Was thinking about doing that, they are screwed in so id have to patch holes somehow Planning on running bigger/wider tires at some point but need to swap out gears (4.56 to 5.29) and not at that point yet. I got the flares for a good deal by trading my old clutch and trans, so I figured id run em. Had 12.5 wide tires then, running a more narrow tire now.
Old 03-11-2014, 09:27 PM
Waylayer's Avatar
This what im working with now. maybe 1" spacers would do it.
Zach_trun
01-22-2020 04:42 PM
94toyy
12
09-14-2015 06:18 AM
fabing455
09-07-2015 08:08 AM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: backspacing-fender flare fit?
