Anti theft is malfunctioning
Old 03-30-2019, 11:44 AM
Smfp21's Avatar
Unhappy Anti theft is malfunctioning
Hi I just bought a 96 4 runner from someone and I believe the antitheft system is overriding my fuel pump. My locks go up and down while I'm driving is why I think it's the antitheft system PLEASE HELP also it seems to flood when the fuel pump is working
Old 04-01-2019, 09:29 PM
thefishguy77's Avatar
Try and get it back to stock if you can. Usually with stuff like this you will find the previous owner or installer thought they were smarter than they were and either took a shortcut, tape and wire nuts sort of deal. Good luck and post pictures of any aftermarket wiring you can find...
The following users liked this post:
Smfp21 (04-02-2019)
Old 04-02-2019, 11:34 AM
old87yota's Avatar
Thefishguy77 brings up a good point.
Is your system an original Toyota system or did someone add an aftermarket anti-theft system later?
Old 04-02-2019, 05:16 PM
Smfp21's Avatar
its the original . there is a switch installed by previous owner under driver side panel that i cant figure out what it goes to. i actually got the fuel pump to operate but it wont start all the way
Old 04-02-2019, 05:24 PM
Smfp21's Avatar
it caught on fire when i tried spraying starter fluid in the air intake if that helps identify.a specific problem. it ran not that long ago for a few days. i cleaned the injectors it was flooding right away when starting it and it ran. my husband sprayed seafoam in the air intake and it started idling a lot better immediately. while revving it to clear it out it stalled and hasnt started since.
Kaleb
266
07-15-2013 05:26 PM
Babypig
08-13-2004 05:59 AM
Corey
9
03-03-2003 04:21 PM
smr4runner
08-16-2002 10:26 PM
Quick Reply: Anti theft is malfunctioning
