Alignment get thrown off when engaged in 4x4
I have a Toyota x-cab With Manuel hubs and when I throw it in 4x4 and drive, the tires look like this \.../
But the story is that I wAs wheeling up a steep rock and my tires didn't grab traction so I went again, but this time I gave it more gas and up it goes but also had little traction at the same time. The tires was slipping but still spending and I made it. After we were done I pull onto the road and notice my front tires was super wobbly. So I engaged it back to 2wd and the wobble was gone. Also when in 2wd the tires are straight and not like this \.../
So I do not know what can be the problem and any advice will be great. Thanks
I found the problem. The front diff is shot. I wAs checking all the bushings and what not and it all look good. Then I got to the axles and the passenger side was way wobbly. The gears on the inside is probably all grind up. Will I guess it's time to regear! hahahaha thanks all you guys for the advices.
