99 4Runner Upper Ball Joint Problem
Old 05-24-2012, 03:42 PM
hatda02's Avatar
I searched on here and everyone says replacing the ball joints is an easy task on the 3rd gen 4Runner. The lower was no problem on or off. The upper had a good amount of rust and I had to beat it for about 5 mins with a BFH before it popped out. Now the new one will not easily slide in.
From what I read I don't need to press it is. It seems way too tight for it to pull in place when placed in the UCA and starting to thread.
Am I missing something obvious? I did sand out the old hold removing any of the old rust.
Old 05-24-2012, 04:31 PM
aa1911's Avatar
you're supposed to press those out with a tool, you can rent it free at autozone.
I get to do mine before too long.... hooray!
Old 05-24-2012, 04:45 PM
hatda02's Avatar
What about going back in tho?
Old 05-24-2012, 05:04 PM
hatda02's Avatar
Never mind. Found this through a link of a link of a link.
http://www.bajataco.com/tech/control_arms_04.html
Old 05-24-2012, 06:39 PM
rworegon's Avatar
The method in that thread looks like a pain. Do what aa1911 suggested the press is used to remove and also reinstall the new ball joint. It takes a good bit of force to get it out and back in.
MMA_Alex
25
04-18-2017 05:07 AM
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 99 4Runner Upper Ball Joint Problem
