95 T100 Fuel System Diagram
Hi I am looking for a fuel system diagram, specifically where the two hoses (other than the fuel line) hook up to the fuel tank. I know one is a return line and the other is some type of vent. I recently swapped out the fuel tank and want to make sure I have them right. One comes from the fuel pump bracket and the other from the top of the tank.
1995 Toyota T100, 3.4L, V-6, 4x4, Reg Cab, drivers side fuel tank.
Thanks.
Thanks.
How did you make out regarding your T100 fuel tank. Its funny but Im having the same issue however I already hooked mine up and then had fuel spewing all over the place. I was wondering how these lines work. I did some rehab work on this fuel tank and not sure if I screwed up some things.
WOuld this occur if I had the two lines reversed?
I just went through the same problem. I hooked the vent and the return line backwords. That caused the fuel tank to pressurize and caused fuel to pour out the vent. On my 85 the shorter fuel line goes to the farthest hole in the tank.
TURBOrunnerNM
07-22-2015 11:01 AM
