'94 T100 3vze jumping speedo/noise/engine hesitation
Old 09-26-2012, 04:02 PM
gobbler87's Avatar
Hey all,
I drive a '94 T100 4wd 3vze with a 5 speed manual transmission. I've been looking around at a lot of other threads on the site and have found solutions to similar issues, but nothing quite like what I'm experiencing. About a month ago I was cruising around 75 mph and noticed my speedometer started bouncing around erratically. This was accompanied by a screeching from under the hood (sounds like a bad belt, but I replaced those last summer and they looked fine when I checked them) as well as some hesitation in the engine. This only lasted for that one trip and then subsided until about a week ago and now it happens consistently. I know I should have looked into it more when it first started, but as a broke masters student, I find myself putting off maintenance issues until the last possible minute. I know this is terrible and I apologize for any tears I may have just caused for any of you. Anyway, the engine hesitation only happens, or I should say is only noticeable, at higher speeds (50+). But, the speedometer will bounce around for a few minutes and then go steady for a few, only to start bouncing again at all speeds. I've read where other guys have had issues with the speedometer bouncing and making noise caused by a bad sensor or cable, but no mention of any hesitation from the engine. Any suggestions? Thanks in advance for the help!
jashoeuh
11-26-2017 07:01 AM
4runnerstalls
08-26-2015 11:13 PM
HollieJayyy
08-09-2015 07:59 AM
91yotapup
07-27-2015 07:19 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: '94 T100 3vze jumping speedo/noise/engine hesitation
