94 pickup newb questions
Im in the process of doing some general maintenance on my 94 pickup and I have a couple of questions. First off, is there any trick to replacing the fuel filter, as far as I can tell it is a complete bitch to get to. Secondly, I hear a belt squeal sometimes and I have a hunch it is the belt connected to the air conditioning compressor. I no longer use the air conditioning cause it has many problems so can I simply just remove this belt? And finally, anyone know where I can find the layout of the fuses in the fuse box in the engine compartment. I no longer have the top piece of the fuse box. Thanks
creswell, Oregon?
helps to know if you have a 22RE 4 banger or a 3.0 Slug V-6...adding that information to your sig helps out.
You can download the Service manual for your truck using the link in my signature...it will have the info you need for the wiring diagram etc
AC belt, yes you can remove that as long at the belt is not routed to another accessories, don't recall the routing on a 3rd gen truck, still haven't owned one yet
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Fuel pump: welcome to the club...
AC belt: Yes, you can cut it.
fuse box cover: Sorry, don't haver one. You try googing it?
creswell, Oregon?
Yeah, Creswell OR
The belt only goes to the compressor as far as I can tell so I think im gonna go ahead and cut it.
Thanks for the help.
As long as you're changing the filter, move it inside the wheel well. Bolt or zip the bracket to a bolt through the well inside the engine compartment. NOT a big deal, it's a common sense mod. Makes it REALLY easy to get to!
You're just moving the filter up a bit, inside the engine compartment, off to the side.
Just added an edit to my post: You're just moving the filter up a bit, inside the engine compartment, off to the side.
Don't want you to get a strange idea as to where to relocate the filter... Yes, it's up near the engine, but on the intake side.
Yeah I understood what you meant. haha
link? Never mind... Wrong filter...
If you mess with the fuel filter be prepared to replace some fuel lines as well that thing is usually corroded into one solid piece and taking it apart breaks things...
I replaced mine with a GM filter when I finally had to replace it. Its much easier to work with now and parts are avail. everywhere and it's easier to service now too...
fuel filter
TURBOrunnerNM
07-22-2015 11:01 AM
