92 toyota "bucking" in 1st gear?
Old 12-15-2011, 06:22 PM
BIGR79's Avatar
My 92 with 3.0L just started "bucking bad" when starting out in 1st gear, at the same time the idle went from 800 down to 200-300 rpm's and most of the time dies, anyone got any ideas what suddenly caused this?
Old 12-18-2011, 03:02 PM
matthew22r's Avatar
does it free rev fine? does it only buck at full throttle under a load?
im not well versed in your motor, but it could be a Throttle position senor?
I have heard of coils going bad in a way were you could get bucking under a load, but a coil would run bad in all gears.
Old 12-18-2011, 03:10 PM
rworegon's Avatar
Did you do any work right before this bucking started?
Check all your vacuum hoses and air intake tube for cracks, leaks, disconnected, etc.
Old 12-18-2011, 03:24 PM
Jkelley429's Avatar
x2 on the vacuum leak
Old 12-18-2011, 03:52 PM
AMSevo8man's Avatar
Check the distributor cap also. Mine 22re was doing that too, but only when it rained. I replaced the cap and rotor button and now its fine.
Old 12-19-2011, 08:52 AM
BIGR79's Avatar
Thanks guys,
The intake tube was split on the backside!
Now that it's running I am trying to time it, with cap turned all the way one way the most advance I can get is 9 deg, I turned the distributer gear a tooth now the lowest I can get is 16 deg, I'm looking for 12 though it won't let me! Is there a chance I have the wrong distributer in my truck?
voiddweller
19
05-02-2016 09:10 PM
YotaLogic
12
11-17-2015 06:27 AM
ACZR
06-23-2015 07:55 PM
RyanJ989
06-21-2015 06:40 PM
Mr.Black
06-21-2015 10:17 AM
Quick Reply: 92 toyota "bucking" in 1st gear?
