92 22re.. no knock sensor found. is there one?
Old 09-17-2012, 06:12 PM
jmswltn's Avatar
i went to my local pick and pull today to get the rest of my r - re swap parts and the motor didnt have a knock sensor or wiring for it. i pulled the entire ecu harness and ecu out myself along with the afm, coil, and distributor. there is nothing left but block and head.. no wires no sensors.
the truck is a 1992 with a w55
side of block
door jamb tag
did they make this one with out a knock sensor?
Old 09-18-2012, 01:44 AM
maco35's Avatar
I think 2wd trucks don't have them, but somebody else will know for sure.
Old 09-18-2012, 01:48 AM
drew303's Avatar
the hole for a knock sensor on that block obviously never had anything in it. Dunno if the 2wd just didnt come with one or what (odd?) but where one should go, the hole on that block says its not been penetrated in a long time.
Old 09-18-2012, 01:50 AM
drew303's Avatar
come to think of it i gave a buddy of mine a knock sensor for his 2wd. It had one and was throwing a code that the knock sensor was well detecting a knock or malfunctioning so to rule it out i gave him an extra i had.
so yea 2wd 22re had a sensor, atleast his did.
Old 09-18-2012, 03:13 AM
maco35's Avatar
May be it was carb'd?
Old 09-18-2012, 03:36 AM
jmswltn's Avatar
Its there a way to find that from the door tag.. The truck was complete before I touched it
Old 09-18-2012, 07:33 AM
maco35's Avatar
The reason why i say the truck was 2wd is the tire size, on the door tag says 195/75/14.
Old 09-18-2012, 08:55 AM
westjohns yota's Avatar
my 86 22re doesnt have a knock sensor, not sure of the reasoning behind it
Old 09-18-2012, 02:24 PM
slow-mo's Avatar
By inputting the VIN, that engine comes up as a 22RE (EFI), not carbed.
http://www.toyotapartseast.com/Page_...FJ11&VAID=2365
Old 09-23-2012, 12:33 PM
jmswltn's Avatar
it may only be 2wd re's that lose the knock sensor.
here is a pic of the ecu tag and pinset
Old 11-29-2012, 05:39 PM
red450r's Avatar
I put a 2wd 93 cab on my frame after totaling my truck and it doesn't have a knock sensor either. I'm getting a really bad pinging sound under a load, cel blinks a few times but never throws a code
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
djohnson13
09-04-2015 12:35 PM
moparbay
09-03-2015 12:48 PM
northwalker
09-03-2015 12:21 PM
Quick Reply: 92 22re.. no knock sensor found. is there one?
