90 3VZE truck starts and dies, wont stay running
Old 12-18-2011, 11:34 AM
88Mr290Pickup's Avatar
Pretty confident in the top end. Using the stick-as-stethascope method, I've narrowed the knock down to the bottom end near the bell housing.
Going to yank the starter and the grommet around the clutch fork and look around in the bell housing. Maybe I'll get lucky and find something loose. I know it's a long shot. It did not knock at all when I ran it by squirting fuel into the intake.
When I bought the truck + rebuilt motor, it came with a copy of the receipt from the rebuild shop. I called the shop before I forked over any cash and asked if the warranty would apply to me as well, they assured me it would provided I had a copy of the receipt. Monday I'll be calling them and we'll see what's up.
Old 01-02-2012, 12:19 PM
I have contacted the shop that rebuilt the engine, too much time had elapsed and the engine was no longer under warranty.
Current plan is to scrap all the 3VZE stuff and swap in a Mercedes diesel, although it may be easier to ditch the current truck and trade it for a 4 cylinder version. I have cash in hand for an OM617.952 in good running condition, in the car would be best, near Salem, OR.
Old 01-08-2012, 03:58 PM
The V6 saga is officially concluded.
Yesterday I purchased a fine running OM617 and today I began dismantling/removing the knocking V6. I'll be ordering the adapter from 4x4 labs shortly.
I'm looking at a lot more work than installing the V6 was, but now I'M SMILING about it. Should have skipped the V6 and went with this diesel from the very beginning.
Anyone want to buy a knocking 3VZE and the other V6 gas support parts, let me know.
Old 04-08-2012, 05:52 PM
andrew1586's Avatar
Nope I'm killn it, then different
Old 12-14-2016, 05:23 AM
  #25
Coin420's Avatar
Similar issues
Originally Posted by 88Mr290Pickup
Starts on the first crank. Idles beautifully. Revs smoothly.
So much bottom end rod knock it sounds like someone forgot to put bearings in one of the connecting rods.
Not sure what the plan is now. Would love to yank the motor and proceed directly with the Mercedes diesel swap, but money is tight and time is short.
Pretty discouraged right now. First time I have EVER trusted someone else's rebuild, and now I know why. Any ideas?
so ... im likewise having what seems to be an inector related issue.. swapped old 3.0 for another 3.0 known to be a runner. fired up after the swap ran solid but had a miss due to a broken inj clip wire. i had to wire pigtails for inj .. all tests came back good . inj pulse present on all 6 . should i have continuity on both banks? all negs and all pos. across both banks. ive refinished every ground cleaned every surface and even vaselined each to prevent corrosion . ive checked tps.. maf...jumpering b+ to fp ... everytime same result ..... engine fires ..sounds good revs to about 800 to 1100 .... and then dies. im also getting excess fuel in my airchamber behind the throttle body.. anyways id greatly appreciate any advice you may have . thanks
zd92655
03-06-2022 12:58 PM
91toybeater
12-27-2015 07:46 PM
Alex Bessinger
06-28-2015 10:05 AM
ibayne
06-26-2015 06:30 AM
slider417
06-22-2015 10:18 AM
Quick Reply: 90 3VZE truck starts and dies, wont stay running
