86 4Runner 22RE dizzy question
Old 08-23-2012, 09:59 AM
kushiel's Avatar
The air gap is larger then what the FSM suggests.
If I understand this correctly air gap is the gap between the black thingy (with the two wires) and the thing with the 4 pointy things (center).
So I rechecked this today and the gap is like 5 mm as you can see on the photo.
This is bad I take it (I have a whole thread about the 4runner not starting)
I noticed that there are two screws holding in all the stuff for the pickup coil. Can I just replace that or to I need to replace the whole dizzy? Or can I readjust that piece so it's closer?
If I need to place it, where can I find that part? I know a parts yard but other places.
Thanks!
ara
Old 08-23-2012, 01:51 PM
Bingle's Avatar
loosen screws and slide over till you have correct gap between magnet and points on the "star". Use a feeler gauge. Check the fsm for your year for the correct gap if you don't already have that info.
Old 08-23-2012, 01:54 PM
kushiel's Avatar
@Bingle
Thanks!
mskalmus
05-28-2017 07:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
TURBOrunnerNM
07-22-2015 11:01 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 86 4Runner 22RE dizzy question
