85 Toyota Pickup 22R Keeps Blowing 80 Amp Fuse
Old 07-22-2022, 04:37 PM
RustyFrames's Avatar
Exclamation 85 Toyota Pickup 22R Keeps Blowing 80 Amp Fuse
I have been playing with these trucks since 1985 and have never ran into an issue like this. I put a new carb on the truck like I have before and then the 80 Amp fuse started blowing. The only wires that I moved was the plug when I unplugged it and plugged it back in. I was happy it started and ran though. Right off the bat I replaced the ignition switch since it was the original. I then unhooked the starter, Alternator and carb plug. Turned the key and poof there goes the fuse. Looked deeper and found a wire that was rubbing at the fuse box. Repaired it, left everything else as it was. Turned key switch and then poof went another 80 amp fuse. All the ground straps have been checked and verified for proper connections. I am at a loss. Any ideas??
Old 10-31-2022, 05:19 PM
UPDATE: The issue was a short within an electrical component of the new carb.
The following 4 users liked this post by RustyFrames:
millball (10-31-2022), Nervo19 (11-02-2022), old87yota (11-01-2022), RAD4Runner (11-01-2022)
Old 11-05-2022, 07:08 AM
jeremy harp's Avatar
how did you solve it ?
Old 11-06-2022, 02:19 PM
I was basicllay working on something else and saw the old carb sitting in a box. I then decided to go back to the last thing I had done before this issue cropped up. I simply put on the old carb and now it works fine except I need to do some work on the carb.
holypinkhobo
01-13-2022 04:27 AM
cskeegan8
06-18-2020 11:55 PM
deepthinker22
04-11-2019 04:38 PM
i<3maToy
06-28-2012 05:28 PM
tysen86
08-28-2011 04:51 PM
Quick Reply: 85 Toyota Pickup 22R Keeps Blowing 80 Amp Fuse
