85 Toyota 22RE 4wd EFI and fuel system question.
Old 04-24-2013, 08:21 AM
Staff
Terrys87's Avatar
Thanks 4Crawler for all of the great information you have posted in the past. I have references saved from your post throught my build threads for quick references.
Joecool.. A paperclip is what triggers the diagnostic codes in these truck and you go by the flashing check engine light for codes and also for jumping connections to perform other test.
The Air Flow Meter Vane that you are asking about is what the black pipe that goes from your air filter to the Plenum. If you remove the black pipe from the air filter assembly you will see a flap in there that is moved when the engine pulls air thru the filter to the plenum.
Your Check engine codes will be on the bottom picture for the 85 and 86 model trucks. The top picture is for 87 and newer trucks. Just posted the infor for others that might not be sure how to get the codes. Also I just used a piece of wire as I did not have a paperclip at the time of the picture but is more for a reference.
Codes... http://4crawler.com/4x4/CheapTricks/...es/index.shtml
How to get Check Engine Codes. I just put this up for others. Applies to 87 and up. 86 and older is the bottom picture.
The Diagnostic port for the 85-86 is on the Drivers side inner fender and is nothing the same as the 87 and up. Here is T1 and E1 jumped. The codes and engine flashes are the same as the rest of the trucks on the dash.
Codes...http://4crawler.com/4x4/CheapTricks/...es/index.shtml
http://www.youtube.com/watch?v=9qEQM...ature=youtu.be
Old 04-24-2013, 09:48 AM
joecool76's Avatar
Will fuel pump operate directly,with E1 and T1 jumped?
Old 04-24-2013, 10:09 AM
4Crawler's Avatar
Nope. You need to jumper the fuel pump connector (Fp and B+), that is the rectangular 2-pin plug (red circle) in the above photo.
Old 04-24-2013, 10:42 AM
joecool76's Avatar
Okay,I think I have located and/or matched the plugs on my truck with the above photos and descriptions.Thanks for the great info.
There are two other plugs with this group of plugs on my truck,another smaller round on and another square one with one yellow wire.Are you familiar with these other two plugs and their porpose?
Old 04-24-2013, 10:48 AM
  #25
joecool76's Avatar
Also,are there any other airflow meters or main points that could be a problem in my circuit or fuel system?
Old 04-24-2013, 11:20 AM
  #26
4Crawler's Avatar
Small round / single wire connector is likely the O2 sensor raw signal. Not sure on the square one, look in the FSM ECU wiring diagram section for a starting point.
Old 04-24-2013, 11:22 AM
  #27
4Crawler's Avatar
Where is air flow meter vane located?
It is inside the Air Flow Meter:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
What can affect the fuel pump/testing:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Diagnostic connectors and how to pull/interpret codes:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old 04-24-2013, 11:41 AM
  #28
joecool76's Avatar
Do you know the basic procedure of diagnosing vehicle by turning key on,and check engine light on or off blinking ,doesn't come on or stays on or something like that and what it means?
Old 04-24-2013, 11:51 AM
  #29
4Crawler's Avatar
Right on the web page:
- http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Old 01-17-2021, 07:41 PM
  #30
Wes Dickson's Avatar
Is the a water valve under the hood of that total?!
Originally Posted by 4Crawler
See below:
Driver's side fender:
Old 01-17-2021, 07:46 PM
  #31
4Crawler's Avatar
Yes, that's for the hot water shower. That valve is what controls the flow of coolant engine through a heat exchanger and thus adjusts the temperature of the shower water:
https://www.4crawler.com/4x4/CheapTricks/Shower.shtml
joecool76
07-04-2019 11:07 AM
joecool76
04-16-2014 05:19 PM
jasonjuch
12-28-2009 07:28 AM
bryonb
09-12-2008 03:40 PM
Quick Reply: 85 Toyota 22RE 4wd EFI and fuel system question.
