85 Toyota 22RE 4wd EFI and fuel system question.
Old 04-17-2013, 06:03 PM
joecool76's Avatar
My 85 22RE 4wd is not pumping any fuel.Does anyone know the main points I should check?Any diagrams?
Old 04-17-2013, 06:11 PM
uncleblues's Avatar
plenty of info to be had on this. I suggest going to 4crawlar's site to begin with. open the diagnostic thingy next to your underhood fuse box and jump b+ to fp with his special diagnostic tool. that will tell you if the pump runs. work backwards along the circuit from there.
Old 04-17-2013, 06:12 PM
uncleblues's Avatar
sorry-4crawler
Old 04-17-2013, 06:39 PM
Gizler00's Avatar
X2 on above suggestion. Start with the basics. Is the fuel pump working, does it have power , is fuel filter plugged, Etc....
Old 04-18-2013, 07:55 AM
4Crawler's Avatar
Start here:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old 04-23-2013, 06:41 PM
joecool76's Avatar
I am having locating the plug or box where I use jumper.My truck is a 85.Do you know which of the diagrams should be like mine?
Old 04-23-2013, 06:53 PM
4Crawler's Avatar
See below:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Driver's side fender:
Old 04-23-2013, 07:29 PM
joecool76's Avatar
So,the same square plug should be located on my drivers side fender?What should I use as a jumper?
Old 04-23-2013, 07:31 PM
joecool76's Avatar
Also,I have a picture of my drivers side inner fender,if you know a way I can send it.
Old 04-23-2013, 08:52 PM
4Crawler's Avatar
It is a round plug (circled in light blue as noted on the above web page, typically with 2 wires/terminals (the T and E1 terminals) and yes you use a jumper wire.
Old 04-24-2013, 06:44 AM
joecool76's Avatar
I looked at my truck yesterday.It's a few miles away from here,so it's not right here.I didn't notice any round plugs going into the inner fender as shown in the picture.I also have a misunderstanding about which plug to use the jumper in(square circled in red)(small round circled in blue).
Old 04-24-2013, 06:45 AM
joecool76's Avatar
Thought it said to use jumper in square plug circled in red.
Old 04-24-2013, 06:54 AM
4Crawler's Avatar
That is the fuel pump test jumper plug.
Old 04-24-2013, 06:56 AM
4Crawler's Avatar
May not be inserted into the round rubber plug holders, they might just be hanging down loose. Blue circle is diagnostics plug (for reading codes, setting timing), red circle is fuel pump test jumper (turns on the fuel pump for testing), green circle is O2 sensor testing connector.
joecool76's Avatar
When I turned the ignition on to check and see if the fuel pump was working ,(by seeing if it was pumping fuel out of the gas line that goes into the fuel filter) the efi tank was disconnected from the intake manifold,which is and was connected to the block.Are there any sensors that would prevent the fuel pump from working with that disconnected?
Old 04-24-2013, 07:00 AM
4Crawler's Avatar
Fuel pump won't normally run when the key is on (only). It either needs the Air Flow Meter vane open or the fuel pump test jumper installed:
Old 04-24-2013, 07:02 AM
joecool76's Avatar
Also some hoses and maybe plugs not connected to the efi tank.Do you think that could be why my fuel pump wasn't pumping fuel with ignition on?
I wanted to see if the fuel pump was working and didn't realize that there were sensors or anything else that would keep it from working.
Old 04-24-2013, 07:04 AM
joecool76's Avatar
Where is air flow meter vane located?
Old 04-24-2013, 07:08 AM
joecool76's Avatar
What all can I do with (green circled sensor testing connector"?
Old 04-24-2013, 07:13 AM
joecool76's Avatar
Do you know of , where I can buy,an instrument, or what I can use to check or get code readings?
Quick Reply: 85 Toyota 22RE 4wd EFI and fuel system question.
