85 toy 4runner fuel gauge
hello, thanks for taking the time to look and maybe answer my question , my 85 4runner's fuel gauge swings up and down when I'm driving , and then when I stop it will slowly stop. thanks
when you say it swings you mean rather fast moving up and down.
Not just the normal swing from the going up and down hills.
If the first you have a pinched wire or a loose connection some place
Your sending unit works on resistance so if this changes the needle will move.
Trouble Shooting electrical problems the Toyota electrical manual is a great help.
If you have never seen a sending unit it has a wound copper section that a arm moves up and down depending on the level of fuel in the tank.
As the resistance changes the needle moves.
I am thinking more electrical then mechanical because more then likely if there was a problem with the wiper it might not work at all.
Last I looked into a new sending unit with new hardware it was about $120.00
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
