'85 crossover steering help
Old 03-14-2010, 03:04 PM
jojogreen222's Avatar
I have a '85 truck that currently has the stock steering and no lift. I have all of the parts for the crossover steering conversion, but when I hold the parts about where they should go, it doesn't seem like they will fit. Do I need a lift in order to put the crossover on? any help would be greatly appreciated.
Old 03-14-2010, 03:07 PM
yoder519's Avatar
yes you need a minimum of 3inches to clear it im thinking. bu ti may be wrong. check out trail-gear.com it says it on there
Old 03-14-2010, 03:14 PM
so can it be a body lift or does it need to be suspension?
Old 03-14-2010, 03:25 PM
yoder519's Avatar
suspension. it has to have enough room in between the axle and the bottom of the truck. someone that has done this before wil chime in here shortly
Old 03-14-2010, 05:34 PM
rattlecanpaint's Avatar
Yea you need some suspension lift or the drag link and tie rod will hit the oil pan.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
ktm192k
10-01-2015 08:47 AM
Quick Reply: '85 crossover steering help
