5vzfe timing belt help
Thanks.
Just line up the marks, and you will be fine. The reason its "popping" is because the valve springs are trying to force the valve closed.
You shouldn't have any timing issues what so ever as long as your match marks are ok. The cam can spin either way without any issues.
Yeah, that probably isn't good, chances are the belt was installed incorrectly (off by a tooth somewhere).
At this point, I would remove the belt then turn each pulley individually to get all the timing marks lined back up then install the new belt. If I remember correctly, the passenger cam will want to "spring forward" when the timing marks are lined up and can be a bit of a pain to work with.
As for clockwise vs. counter-clockwise, the FSM says to only turn the motor over in a clockwise direction, which I'm sure they state for a reason, but I have rotated my cam gears counter clockwise (in a very small amount, maybe 1/16 of a rotation?) and haven't seen any problems.
What I do is get the belt on the driver side cam and then use a soft jaw spring clamp to hold it in place. Then I use a breaker bar and socket on the passenger cam bolt to control the jump while placing the belt on the cam and one on, place a clamp on it.
Sometimes if the belt is fighting me, I'll use a ratchet/breaker bar on the driver side cam bolt and then turn it counter-clockwise to get a little slack while turning the driver side side very slight clockwise.....this works for me to get both belt on both cam TDC marks.
#25
Yeah, a breaker bar works best for me to control the valvebounce(as I call it). Ratchets tend to spring one way or the other, the breaker bar will hold it as long as you're holding it. If you got a buddy who will help hold it, that works too.
The biggest issue I had was trying to do this all while I had the tensioner still in. I realized its so much easier if I just reset the tensioner and put a pin in it than trying to fight it.
#26
Off an inch
I am replacing my water pump and I am at the point now where I need to take the timing belt off but the crank marks are off an inch when the cam marks are at tdc. What would cause this to happen, truck seems to be running fine. Also the crank bolt was very easy to loosen. I had the belt replaced 30000 miles ago and the water pump is leaking. What do I do? Should I align the cam marks before I pull the belt and rotate the crank aligning the marks when I put the new belt on?
The timing marks on the old belt will (just about) never line up with the timing marks on the cam and crank pulleys; this is expected.
Line up the timing marks on the cam pulleys with the paint dot on the rear timing belt cover, or line up the timing mark on the crank pulley with the mark on the oil pump; don't look at the marks on the belt, they're only there for proper alignment at install. If all 3 pulleys don't line up, rotate the crank a full rotation and check again.
When you install the new belt, make sure all timing marks line up and that the marks on the belt match the marks on the pulleys (assuming an OEM Toyota belt). With all the idler pulleys installed and the tensioner released, rotate the crank 2 times and verify that the timing marks on the pulleys match up with the reference points; the marks on the belt will be off a tooth or 2 (again, this is expected).
#27
The 5vz-fe is a non-interference engine so you can rotate both cams and crank without issues when the belt is off.
Be sure to torque the crank bolt to 217 ft-lbs when reinstalling.
#28
Are you saying that when the marks on the 2 cams are at 12:00 (and lined up with the marks on the timing cover) that the mark on the crank pulley is an inch away from the mark on the oil pump? That would not be good, and yes, make sure all the marks are lined up correctly during re-assembly.
Even though the belt only has 30K on it, I would go buy a new TOYOTA timing belt (either from a dealer or one of the many Amazon/eBay sellers) for $60 or so, which will have all the correct marks on the belt which makes the re-assembly that much easier.
#29
#30
I assume you're only looking at the marks stamped into the crank pulley and oil pump and the 2 cam pulleys and the rear timing cover, and not trying to align the marks on the belt.
#31
What mark on the crank gear did you line up to the oil pump? Hopefully, it was the small dimple that sits below one of those small teeth on the crank gear.
The right hand picture in post #5 shows the proper crank TDC alignment: https://www.yotatech.com/forums/f120...-5vzfe-285210/
Did you replace the front seal and possible bend or break off on of those crank timing gear teeth?
You do have the intake all installed and all electrical connections are nice and tight?
#32
I'm taking it apart tomorrow to check all the electrical connections. Any other suggestions for me to check, Double check? Thanks
#33
Pin ?.
What pin are you referring to? What's its purpose?
#34
The pin being referred to is the pin (small Allen wrench, small diameter stiff wire) that holds the hydraulic tensioner is a compressed state while installing the timing belt. The pin is pulled after the belt is correctly in position.
#35
#36
They are about a 1/4 inch to the right of the marks on the cam gear backing plate. It looks to me like the belt slipped a tooth and the marks are off now. This isn't surprising since the water pump has had a pretty bad leak and probably got the belt wet.
to4menon4u
03-10-2010 03:48 PM
