4" Suspension Lift on 97 4runner
Old 06-19-2009, 05:05 PM
stockwell45's Avatar
Hey does anyone know of a 4" suspension lift for a 97 4runner? Ive looked everywhere and couldnt find one. I need the 4" for my new 33 x 12.50's so they wont rub, and a body lift will be too difficult because of the auto tranny
Old 06-19-2009, 05:10 PM
whokrz's Avatar
I have only seen 2.5 inch suspension lifts for that gen 4runner.
You could run a 2.5 inch suspension lift and a 1 inch body lift which would give you 3.5.
I don't know how difficult a 1 inch body lift would be considering the tranny.
Old 06-19-2009, 06:01 PM
bummer. well i guess ill start researching body lifts. thanks for the info
Old 06-19-2009, 06:08 PM
pitpatt's Avatar
Checkout www.toyteclifts.com you can find a good setup there. with 33's the 3" OME setup should be pretty decent for you and you shouldnt rub much.
If you want more in the rear you can go with LC coils and to even out the front look for a topout spacer.
Hope this helps you out. Also, PM Crolison he is running 33's with only a 2.5-3" lift. It can be done without much problem
Old 06-19-2009, 06:12 PM
whokrz's Avatar
I really liked my 2.5 ome lift that I had on my old 4runner but I never ran 33s just 31s
http://www.gentryoffroad.com/php/gen...uctreview/ome/
Old 06-19-2009, 06:28 PM
waskillywabbit's Avatar
3" of suspension lift is about all the front CVs can handle, so you won't find a 4" suspension lift, perhaps a 4" bracket lift. You could always do a 2.5" to 3" lift and then add a small body lift if you want.
Search around, lots of lift options for 3rd gen 4Runners.
Old 06-19-2009, 06:49 PM
ey everyone thanks for all your help! I checked out www.toyteclifts.com and i like what I saw. If the 3" system doesnt work out ill try to go for the 1" body lift.
Old 06-20-2009, 08:14 AM
pitpatt's Avatar
yea those are great guys to work with too heard nothing but positives out of them
Old 06-20-2009, 09:56 AM
scuba's Avatar
If you want a 4" bracket lift for a 4runner buy one for a tacoma, they're the same thing.
Old 06-20-2009, 12:00 PM
whokrz's Avatar
If you go with a 3" suspension lift just make sure you get the 1” Differential Spacer it will help your CV angle alot.
Old 06-20-2009, 12:18 PM
SWPERIC's Avatar
my sonoran steel 1.2 kit and 1 in 4crawler BL ROCKS! for me, its the perfect lift for my 285/75/16s. see sig
Old 06-20-2009, 02:28 PM
BajaRunner's Avatar
For 33's you'll be able to fit with around 3" of lift and a little trimming... putting a 1" body lift on is a cake walk, even with an auto tranny. You actually don't even have to touch it.
Old 06-20-2009, 03:26 PM
SWPERIC's Avatar
yea, also the Bl has made my truck 100X easier to work on. doing it b4 your suspension will make the rear shocks easier to get at for sure.
Old 06-20-2009, 09:29 PM
andrewd's Avatar
Agreed! Except i did it in the reverse order ha
Old 06-20-2009, 10:00 PM
SWPERIC's Avatar
o i did too. i just realized it when i was putting the BL on. haha
Old 08-29-2013, 06:45 AM
MR.CAIN's Avatar
I ran 305-75-16's on my 97 4runner w a 2.5 inch spacer lift. just had to get 1/4 in wheel spacers for the front. only cost me 30 bucks
06-01-2021 01:51 PM
09-04-2015 09:27 AM
akaphilly
07-09-2015 02:18 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 4" Suspension Lift on 97 4runner
