3rd Gen truck: No compression-coolant everywhere
Old 12-03-2010, 10:19 PM
myotherrideidplastik's Avatar
ok, was going down the highway tonight. hear a pop, and see smoke coming out of the exhaust, instantly, the interior fills with smoke and a baaad smell. drove a few more miles to the next exit, didnt notice much smoke from the exhaust, started to get hot. got to the exit, truck was in red, tigh pitched tap. pulled it out of gear, it stalled, put it in 3rd and it restarted, got to the bottom of the exit, stalled again, died, and steamed and smoked from the engine bay.now when i try to start it, it turns, but sounds like theres no compression. coolant everywhere, will take pix and further description when the sun comes up.
Old 12-03-2010, 10:32 PM
Fossilized
Staff
dropzone's Avatar
in the future please make your thread titles more relevant to your issue: 'so....i broke it'
per the rules could lead to your thread being deleted with out notice.
Also: consider adding your truck info to your signature, by your avatar I can tell your have a 3rd gen but that is about it...the more accurate description you give will help member help you out.
Old 12-03-2010, 10:52 PM
thanks for the info, ill be more descrpitive from here on out. signature changed. i havent done any compression tests or anything yet, but engine turns and dosent catch
Old 12-03-2010, 11:19 PM
peow130's Avatar
blown headgasket
probably.
the water would prevent your truck from running, and the thing would smoke like no other.
Old 12-04-2010, 06:50 PM
Four_hundred_86's Avatar
Sounds to me like the waterpump impeller broke taking out the timing belt and if it is a 3-vze you probably blew the headgaskets when the motor got hot. Not to reprimand but any signs of billowing smoke/ temp getting hot means stop driving NOW!!! Not wait till an exit pull over you probably did more damage by driving it till it died.
Old 12-04-2010, 08:22 PM
i had no choice, it is a busy highway, and has almost no shoulder. its a 22re
Old 12-05-2010, 07:08 AM
Okay wellhonestly tou are better off with it being a 22re. I would pull off the valve cover andlook at the timing chain
Old 12-05-2010, 07:36 AM
Ok, ill do that tonight, and post up my findings.
Old 12-05-2010, 05:57 PM
Sounds good
Old 12-06-2010, 05:13 PM
top of radiator is blown out, pulled valve cover and timing looks perfect, oil looks clear, some kind of fluid in throttle body.
Old 12-12-2010, 02:19 PM
ok, just got through pulling the head, the gasket looked fine, theres no scoring on the cylendar walls, underside of head shows only one exhaust port opened, but no coolant in the cylanders. what could have caused the loss of compression to fire the engine?
LittleUgly
15
01-02-2020 01:30 PM
Badlander
10-10-2015 08:05 PM
charlie_fong
09-27-2015 10:06 PM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: 3rd Gen truck: No compression-coolant everywhere
