22re Sputtering....
Old 03-18-2013, 08:13 AM
otis80's Avatar
22re Sputtering....
Well my 85 yoter, 22re, for the past couple weeks it would feel like it was boggin down while driving, then it would be like all the power came at once like the flip of a switch. Then today it started actually spittin and sputterin, i held the bitch to the floor and it sputtered till it got to like 2500rpm then threw you in the seat??? Anyone have any idea, i know, or at least i think i do that its fuel related, maybe clogged fuel filter? I need help ASAP please...
Old 03-18-2013, 08:22 AM
Black_1985_SR5's Avatar
I go over the basics fuel filter fuel pressure make sure there's no water in the distributor
Old 03-18-2013, 08:26 AM
otis80's Avatar
alright and someone told me to check all the vac lines also, sound right?
Old 03-18-2013, 08:29 AM
have you ran it low or out of fuel recently?
Old 03-18-2013, 08:32 AM
otis80's Avatar
Havent ran it out, but i did let it get pretty low, that had me thinkin i may have sucked up some junk out of the tank and clogged the filter
Old 03-24-2013, 10:18 PM
thefishguy77's Avatar
Defiantly do a fuel filter first its cheap and fairly easy. Not as easy as on the third gens with the wheel well hole cut out but not hard. Then go from there. Any exhaust leak sounds coming from the engine compartment. Have your checked your distributor for water? If it sounds like your exhaust is leaking the your can spray some carb cleaner on parts under the hood and listen for the engine to race. Also are your vacuum line all hooked up good none have gotten brittle and broken off? Just listing off gremlins that I have had to track in the past.
Good luck and keep us posted
Old 03-25-2013, 03:47 PM
otis80's Avatar
well i did a fuel filter, ran great for a few days, now its right back to where i started....i took some starting fluid to all the vac lines before i did the fuel filter and after and they were fine. And yes it does sound like there may be a little exhaust leak, no i havent checked the distributor, but my buddy said he thought it might be the TPS, could that be so???
Old 03-25-2013, 04:14 PM
Have you ran a can of Seafoam through it yet? Might help clear lines and injectors. I would hate for you to have to chae a problem from tank to engine. Seafoam is the medical Toyota drug
Old 03-25-2013, 06:01 PM
otis80's Avatar
i had thought about that, but no i havent done it yet, il get a can tomorrow, im not sure that i know exactly what to do with it, i had a buddy put it threw my dads tacoma, but i dont remember what it was he did
Old 03-25-2013, 06:04 PM
I put 1/3 in the gas tank 1/3 through the brake booster and I believe 1/3 in the oil. But double check. Just search Seafoam on here you'll get more info than you want
Good luck
Old 03-25-2013, 07:20 PM
otis80's Avatar
ok awesome, gonna keep bumping this up, i need help guys, i read some things on here earlier trying to figure out other problems, maybe the fpr? One person had said the cat, but its been removed, o2 sensor? Im lost and need to fix it asap
Old 03-25-2013, 10:05 PM
I googled the FSM for my truck and found an active link.
This is for a 93 but here's the link
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
You could see if this works for you
Edit. If you noticed an improvement with a fuel filter and then it started doing it again I think it sounds like it could be sediment buildup in the tank. Seafoam might do it but have another fuel filter on hand for after you do I just incase you knock a large chunk of sediment loose. Also if you have the ability drive it aggressively after you foam it that seems to help keep stuff moving through the lines. You might also have to drop the tank if Seafoam doesn't solve it and it gets better again then acts up. I had this problem on my old suburban and it was a clogged intank screen in the tank.
Old 03-27-2013, 12:13 PM
otis80's Avatar
well the seafoam didnt help it...so you think change the filter again. how hard is it to drop the tank?
Old 03-27-2013, 04:59 PM
If the tank is empty or close to it it's not that hard. I know it's easy to ask questions but try going to google and searching for it or just search for your trucks specific factory service manual. You will probably get your answers faster
Old 03-28-2013, 09:52 AM
otis80's Avatar
i know i can do that, but if you didnt come to this site to ask questions, then what is the purpose of this whole forum....???? Thanks
Old 04-03-2013, 11:30 AM
Hummer96's Avatar
Have you checked over your spark plugs and wires recently? They could also be causing your hesitation.
-Aaron
Old 04-03-2013, 06:56 PM
otis80's Avatar
well i went through and would unplug one and start it and did that with every one of em, and it idled different on all of em, so it aint that, or did i check em wrong?
Old 04-03-2013, 07:52 PM
Your problem is turning in to one to ask questions. But the first several we're very easily found by a quick search. There is a lot of knowledge on here and knowing where to find it is how you can find it and help people in the future. I am not trying to bag on you just trying to save you some headache. I watch the newbie forum to try and help people as I was new to this site not to long ago. Most of the people on here will help but they want you to do your due diligence first. Once you get her running good then expand in to the 2nd gen area and you will discover where this site excels. Lots of info on mods and what works and what doesn't work. At least that's what I have found most useful about this site. How not to waste you money building you rig. FYI 85 excab is my unicorn. Had one and I got stolen so I rock my 3rd gen till I find my unicorn. You have a gem for a truck. Enjoy it. I'm jealous of it.
What brand plugs and wires and cap are you running? Some Toyotas are picky for some reason.
Old 04-03-2013, 08:04 PM
maachine's Avatar
sounds like fuel filter is clogged again. you can try running gas from a different source (gas can) maybe. if that solves your problem then you know its sediment in your tank. or just drop your tank and clean it out anyway. with that age, it would probably be a good idea.
Old 04-06-2013, 09:11 PM
otis80's Avatar
fishguy, i have been on truck forums for years, and i know how they work, and i know everyone wants you to search stuff, and i did thats why i posted on here because i didnt find anything i was looking for. Thanks for the complements on the truck. And idk about the plugs and wires, they are whatever was on it when i got it a few months ago. Gonna change all of it out when i get this fuel issue fixed. Maachine, i had thought about that also, inside the gas door it is full of mud from the previous owner, so it has me thinkin there is tons of crap in the tank, my thoughts were to remove the tank, clean it, coat it, new fuel pump, and another fuel filter.
Quick Reply: 22re Sputtering....
