22RE ring end gap
Old 12-12-2008, 10:51 AM
LITLRED's Avatar
22RE ring end gap
I've started assembling my new motor and checked 2 each top and 2nd compression ring end gaps in 2 cylinders and get 0.014 in on all 4. The oil side rail rings are difficult because they move when I insert the feeler guage. These are Rock rings from engnbldr in a fresh 0.020 over '92 block.
Is this gap adequate or should I file them down?
Old 12-12-2008, 10:58 AM
TOYOTA 1's Avatar
sorry, i don't have a book/specs on me as I'm not building a motor right now
but you should lol.. Haynes or Chilton's will have those specs for ya!
if no luck with that, I'm sure someone will chime in with some info..
Old 12-12-2008, 11:19 AM
Windsor's Avatar
FSM says 0.0098-0.0185" for No. 1 and 0.0236-0.0323" for No. 2 compression rings.
Check with engnbldr, they'll have specific details on what you should have and what you should do.
Old 12-12-2008, 11:26 AM
LITLRED's Avatar
ring end gap
The FSM i have shows .25 - .47mm for the top and .60 to .82 for the second, so I'm concerned that the second gap is too tight
Old 12-12-2008, 11:38 AM
LITLRED's Avatar
Engnbldr said i must have a a very good machinist and he's fine with 0.014 in for both compressions. He also said they use OEM rings. So am I wrong in thinking they should have an OEM gap?
Old 12-12-2008, 12:12 PM
Windsor's Avatar
There are a dozen possible reasons for the discrepancy.
I'd trust them since they're the professionals.
Old 12-12-2008, 05:56 PM
TOYOTA 1's Avatar
thats what i was thinking...
also, i thought EB sold only DJ ROCK products?
Old 12-12-2008, 11:05 PM
LITLRED's Avatar
EB told me that the label is DJ Rock but the manufacturer is OEM. At least for the rings.
young buck
18
08-27-2018 02:40 PM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: 22RE ring end gap
