22re Idle Fluctuates While Brakes Are Engaged
Old 06-29-2011, 10:29 AM
CityOfTree's Avatar
Hey Guys,
When sitting at stop lights my pickup's idle will fluctuate (bog down, then rev back up) and it goes through the cycle in about 2-3 seconds, bog down then rev back up again, and again, and again, until I release the brakes then it just idles a little high on its own.
Found one thread that mentioned the brake booster might be the problem, but it looks fine to my uneducated eyes. Checked all the vacuum lines I could find and they all look fine. I did just install a junkyard VSV to the EGR valve cause the one I had the vacuum nipple broke inside the hose, and it threw a code for the EGR, which the junkyard VSV got rid of. I know that my a/c idle pulley is bad too, which I will be replacing later today, but I dont think that would affect my idle this way at all.
Any suggestions would be appreciated, thanks!
Old 06-29-2011, 10:34 AM
Gamma_Hugo's Avatar
https://www.yotatech.com/forums/f116...-surge-232831/
Old 06-29-2011, 10:45 AM
Gamma_Hugo's Avatar
https://www.yotatech.com/forums/f116...urging-203185/
Old 06-29-2011, 10:48 AM
CityOfTree's Avatar
Thanks I will try that this afternoon, in your video, my truck is doing the exact same thing almost!
Old 06-29-2011, 04:28 PM
CityOfTree's Avatar
I cleaned out that valve I saw in the picture (linked thread above) with no change, it wasnt clogged at all, but I still have idle surge with the brakes applied
I cannot find the damn IACV in the FSM, anyone mind giving me a clue so I can clean that out?
Old 06-29-2011, 04:51 PM
Gamma_Hugo's Avatar
https://www.yotatech.com/forums/f116/iac-valve-226680/
its the bottom piece connected to the throttle body. it has 2 small coolant hoses connected to it. once removed, make sure that you can blow air through those 2 little pipes on the IACV, if you cant then they are clogged and most likely is causing your isle surge
Old 06-29-2011, 05:09 PM
CityOfTree's Avatar
Maybe a dumb question, but do I need to remove the TB? If so, I need to go get a new gasket as well...
Old 06-29-2011, 05:22 PM
Gamma_Hugo's Avatar
yeah you do, its kinda difficult to remove it. i had to get new screws because i stripped the ones that connected the iacv to the tb. i didnt put a gasket to the tb, i just used black silicone and so far has been working great.
where in sac are you?
Old 06-30-2011, 06:33 AM
cody o's Avatar
Are you running your a/c while this is happening? If it does this when your a/c is on, but not when it's off, then your idle and a/c fast idle are out of adjustment. The Toyota manual give a procedure to adjust them properly.
Old 06-30-2011, 06:41 AM
snobdds's Avatar
All this misinformation on this thread. Sad.
Your idle is too high causing the surging idle between low and high. It worse when the brakes are applied because the computer cuts fuel to the injectors then a few seconds later put fuel back in the system. Just take a flat head screw driver and turn your idle screw down until it's about 750 RPM when the engine is warm.
FYI - If your IACV was clogged, then you would have no fast idle at inital warm up.
Old 06-30-2011, 07:24 AM
4Crawler's Avatar
X2 on too high an idle speed. Details below:
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
Old 06-30-2011, 07:29 AM
cody o's Avatar
agreed. just make sure you set both idle adjustments.
Old 06-30-2011, 07:49 AM
snobdds's Avatar
The AC has no bearing on what the idle is doing when the brakes are applied. If you set the idle on the throttle body to the correct RPM setting, then in turn it will correct the AC idle up to the correct setting. There is some fine tuning adjustment, however, not enough to make much difference whenthe brakes are applied.
This all assums he has AC, if not then the AC idle up is a mute point.
Old 06-30-2011, 12:12 PM
CityOfTree's Avatar
Thanks for all the input!
Went out and got the gasket for the TB since I was going to clean the IACV, but on the way back from the parts store, it mysteriously started idling fine, WTF?!
I do have a/c and the idle was crap with no a/c on, had not tried it with the a/c....
Old 06-30-2011, 12:32 PM
cody o's Avatar
I have to disagree (but I should have been more specific). The a/c fast idle needs adjustment if it throbs with the brakes applied and a/c on, but is fine with the a/c off.
If it throbs with the a/c off, then it's not the a/c fast idle. Wouldn't hurt to do them both at the same time though.
Old 07-06-2011, 08:01 AM
CityOfTree's Avatar
Clogged IACV was the problem
Hugo was right, I finally took apart my TB and sure enough my IACV had one of the coolant ports clogged. Pulled back the spring loaded diaphram and blew out a chunk of crud, now my truck idles perfect again!
That idle screw was already in all the way so it was not possible to tighten it anymore
Thanks guys
Old 07-06-2011, 08:04 AM
blake.nemitz's Avatar
mine did that and i had the wrong line going to the egr
Old 08-08-2011, 05:05 AM
Sixstring361's Avatar
I have the same issue with my 88 runner 3vze. It's killing me to know what's going on with her. Ive had yotas all my life, but it was the 22re, this is my second v6. I bought it with a 91 runner 3.0 in it, auto trans. I swapped it to a 5 speed without too much difficulty. But the idle has been surging even with the auto in it. It idles right about 12-1300 and when I hit the brakes it surges from 1100-600 and up and down and up and down. --to try to fix the issue I put a booster from a 85 parts truck. Same issue. Any help?
Old 08-08-2011, 05:06 AM
xxxtreme22r's Avatar
idle too high. put your idle at 750-800 where it belongs and I bet that surge goes away. Find out why your idle is high to begin with though, don't just assume it's the idle screw. A vac leak will cause a high idle as well I believe.
Old 08-08-2011, 07:20 AM
4Crawler's Avatar
"It idles right about 12-1300" <- That
See my earlier post.
Quick Reply: 22re Idle Fluctuates While Brakes Are Engaged
