1986 Pickup interior fuse box removal?
Old 11-16-2010, 03:29 PM
tontozerbino's Avatar
Hello all-
My first thread is hopefully an easy one. I've searched and searched for some info on this with no luck. I've looked in some FSM's and couldn't find my answer there, either; I do not have a Chilton or Haynes.
I have a 1986 2wd pickup. I'm trying to get access to some wires and can't figure out how to remove the fuse box/panel behind the driver's side kick/dash panel. The fuse (and relay?) box is a white plastic box with one bolt at the bottom. But it feels held in place on at least one point at the top- I can't see what's holding it and am afraid to use too much force for fear of breaking a tab or screw mount.
Any help would be greatly appreciated,
Thanks
Old 11-23-2010, 12:41 AM
duck tape's Avatar
Btdt
just went through the same situation on my '92
removed fender and wiring harness through body
use long prybar through hole to pry off
Old 11-23-2010, 04:59 PM
wow, really? What was keeping the fuse box attached?
Old 11-23-2010, 05:04 PM
xxxtreme22r's Avatar
why is there two threads by you asking the same thing?
Old 11-23-2010, 10:51 PM
duck tape's Avatar
looks like almost nothing
refer to the pictures
the tab? above the ground wire and bolt
this is the backside of the fusebox
the white plastic with blue dot is your enemy, pry against it
mounting tab? behind ground wire
hole to go through
Old 12-02-2012, 11:42 AM
Yota_guy's Avatar
Hey!! I have a leak behind my kick box fuse panel and I'm having the same problems. Does any body have pictures that could help me with the removal of my fuse panel!
Old 02-27-2018, 01:47 PM
himskim's Avatar
Were you ever able to figure this out? I am having the same problem. Thanks for the help.
Old 02-27-2018, 08:35 PM
RAD4Runner's Avatar
Remove bolt on bottom, Look (IIRC) above and behind the fuse block, find a latch that you press one way so you can slide the whole fuse block up / down.
5280jo
10
07-13-2015 10:05 PM
GorgeRunner
06-27-2015 07:01 AM
Corey
06-25-2002 08:39 PM
Corey
06-25-2002 11:13 AM
Quick Reply: 1986 Pickup interior fuse box removal?
