Spare tire hoist needed
The hoist on my 94 pickup is toast. I tried to free it up and it broke in the process. I found a few used ones on ebay but said they are for a 2wd. I need a 4wd. maybe i can modify where the part that passes thru the center of the wheel to fit mine? anyone know of a hoist off another year that would work on my truck? or any another fix to secure my spare where it supposed to be under the box?
The 4Runner version is a little different.
First it uses a cable but I have never had any problems with it holding 33"
It uses 4 bolts instead of 3 that the truck do but after looking at the cross member on my truck it has the same mounting holes.
The 4Runner version (The type mine is) is a 2 peace shaft connected type, This can be mounted to pickups but you need to drill 1 hole and tap 2 on the frame to make it work correctly.
I will try and post a pic later.
voiddweller
19
05-02-2016 09:10 PM
