Items Wanted Vehicle and non vehicle related
High Temp. Line Pressure Up (VSV)
Old 08-10-2011, 05:18 AM
xylicon's Avatar
I cannot find this part anywhere, apparently its discontinued from Toyota.
I need the VSV for the 'High Temp. Line Pressure Up System' for an 88 22RE
Part No. 90910-12066
(its the blue VSV on the top of the valve cover)
Thanks!
Old 08-10-2011, 05:21 AM
xxxtreme22r's Avatar
in case you can't find one: http://www.toyotapart.com/90910-12066.html
Old 08-10-2011, 11:29 AM
xylicon's Avatar
Thanks for trying to help but toyotapart.com doesn't have it in stock, they said its been discontinued by Toyota. Its the same story everywhere I check,
tell them to update their site then.
Old 08-11-2011, 03:25 AM
coryc85's Avatar
xylicon - I believe I have this part. I'll take a pic tonight and send it to you.
Old 08-11-2011, 07:56 AM
xylicon's Avatar
Awesome!
Old 08-11-2011, 05:06 PM
coryc85's Avatar
I have a valve cover with 3 VSVs on it, here is the blue one:
The number on it is 90910-12085 (OEM Toyota VALVE, VACUUM SWITCH according to toyotapartzone), which is not the number you posted. I'll have to look at the other 2 and see if they match your number.
Old 08-11-2011, 05:52 PM
xylicon's Avatar
Thanks for looking for me but unfortunately that isn't the one I need
Mine looks a little difference than that, mine has one vacuum port on each side.
It looks just like this.
Old 01-22-2018, 11:08 AM
Rgon's Avatar
VSV for pressure up
I ran into the same problem with my 1988 4Runner here is the test for the VSV and the one that is compatible with the 90910-12066.
calderp
Engine Swaps
08-16-2016 05:15 PM
dumpster84
04-30-2016 06:03 AM
calderp
07-27-2015 09:58 AM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: High Temp. Line Pressure Up (VSV)
