Tire pressure sensor/aftermarket rims
So I'm reading that our trucks have tire pressure sensors... does switching to aftermarket rims have any affect this? Just curious.
The only thing that I can see is that the tire pressure light will stay on all the time if you don't put the sensor in the new rims. I'm not sure that the sensor will fit in aftermarket rims. I don't see why they wouldn't fit.
I think some one here could post on this with more information.
If you don't swap the sensor from the stock wheels to the new wheels
you will get a TPMS light on your dash (tire pressure monitoring system).
When I upgraded wheels and tires, I simply unplugged the TPMS ECU, it's behind the radio.
Do a search for Disabling TPMS ECU here or on Tundrasolutions.com/forums/tacoma.
It takes about 45 minutes to complete this mod.
Have you searched on this subject recently?
Just in case you did not, here's the most recent thread that I found after a quick search for "Tire pressure sensor".
https://www.yotatech.com/forums/show...ressure+sensor
read down to thread 11 and you'll find your answer.
Good luck!
Good luck!
06-01-2021 01:51 PM
09-04-2015 09:27 AM
