P0420/430
Old 08-26-2012, 09:29 AM
olalekanbabs's Avatar
P0420/430
My car details; 2005 4runner SRS5 4WD V8 4.7L 84,570 miles, presently VSL trac/trac off & maintenance light came up on dash board. I checked the codes and got P0420 & P0430 Codes, I was thinking of changing the four o2 sensors but a mechanic recommends that I should try catalyst bypass.
Also the fuel consumption is extremely bad.
I was able to use Actron CP9580 to check the car, I know this is tending towards replacing the CAT's, can anyone explain better what the data below means;
2005 Toyota 4-Runner 4.7
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon ok
Sec Air System ok
A/C Refrig Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr n/a
EGR System Mon n/a
This Drive Cycle
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon n/a
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refrig Mon n/a
Oxygen Sens Mon n/a
Oxygen Sens Htr n/a
EGR System Mon n/a
DTCs (Codes)
P0420 MOD $00
Catalyst System Efficiency Below
Threshold Bank 1
PENDING
TOP REPORTED FIX
1-Replaced Catalytic
Converter
FREQ REPORTED FIX
1-Replaced Oxygen
(O2) Sensor
ALSO REPORTED FIX
Converter Gasket
P0430 MOD $00
Threshold Bank 2
PENDING
FREQ REPORTED FIX
Converter
State OBD Check
MIL Status OFF
Codes Found 0
Monitors OK 5
Monitors Inc 2
Monitors N/A 4
Record Data
FRAME: -1 TM: -4.6
MIL STATUS Off
ABSLT TPS(%) 19.6
ENG SPEED(RPM) 0
BARO PRS("HG) 29.5
CALC LOAD(%) 0.0
MAF(LB/M) 0.20
COOLANT(°F) 201
IAT(°F) 169
IGN ADV(°) 5.0
SECOND AIR N/A
ST FTRM1(%) 0.0
LT FTRM1(%) 7.0
ST FTRM2(%) 0.0
LT FTRM2(%) 10.9
VEH SPEED(MPH) 0
ABS LOAD(%) 0.0
FUEL SYS 1 OPEN
FUEL SYS 2 OPEN
REL TPS(%) 0.4
THROT CMD(%) 16.5
ABS TPS B(%) 51.8
ACC POS D(%) 15.7
ACC POS E(%) 31.8
CAT TEMP11(°F) 996
CAT TEMP21(°F) 996
CAT TEMP12(°F) 746
CAT TEMP22(°F) 746
EVAP PURGE(%) 0.0
ABS EVAP VP(H2O)403.2
CMD EQ RAT 0.824
O2S12(V) 0.015
O2S22(V) 0.015
O2S11(V) 4.001
EQ RATIO11 1.000
EQ RATIO21 1.000
O2S21(V) 4.002
MIL TIME(h:m) 00:00
CLR DIST(mi) 26
CLR TIME(h:m) 05:32
CLR TRPS 3
MIL DIST(mi) 0
VPWR(V) 12.226
ENG RUN(m:s) 00:00
OBD2 STAT CA
O2 Monitor Tests
Not Supported by Vehicle
Diag Monitor Tests
O2 Sensor B1S1
Test $8E
MOD $00
MAX 0.000(V)
MEAS 0.000(V)
MIN 0.000(V)
STS OK
Test $91
MOD $00
MAX 0.000(mA)
MEAS 0.000(mA)
MIN 0.000(mA)
STS OK
O2 Sensor B1S2
Min V for Cycle
MOD $00
MAX 0.195(V)
MEAS 0.097(V)
MIN 0.000(V)
STS OK
Max V for Cycle
MOD $00
MAX 1.190(V)
MEAS 0.859(V)
MIN 0.605(V)
STS OK
Test $8F
MOD $00
MAX 2.998
MEAS 0.007
MIN 0.000
STS OK
O2 Sensor B2S1
Test $8E
MOD $00
MAX 0.000(V)
MEAS 0.000(V)
MIN 0.000(V)
STS OK
Test $91
MOD $00
MAX 0.000(mA)
MEAS 0.000(mA)
MIN 0.000(mA)
STS OK
O2 Sensor B2S2
Min V for Cycle
MOD $00
MAX 0.195(V)
MEAS 0.078(V)
MIN 0.000(V)
STS OK
Max V for Cycle
MOD $00
MAX 1.190(V)
MEAS 0.898(V)
MIN 0.605(V)
STS OK
Test $8F
MOD $00
MAX 2.998
MEAS 0.001
MIN 0.000
STS OK
Catalyst B1
Test $A9
MOD $00
MAX 9.994
MEAS 0.005
MIN 0.039
STS LOW
Catalyst B2
Test $A9
MOD $00
MAX 9.994
MEAS 0.005
MIN 0.039
STS LOW
Purge Flow Mon
Test $C9
MOD $00
MAX 4.752(PSI)
MEAS 0.026(PSI)
MIN 0.000(PSI)
STS OK
Test $CA
MOD $00
MAX 4.752(PSI)
MEAS 0.348(PSI)
MIN 0.000(PSI)
STS OK
Test $CB
MOD $00
MAX 4.752(PSI)
MEAS 0.217(PSI)
MIN 0.000(PSI)
STS OK
Test $CD
MOD $00
MAX 4.752(PSI)
MEAS 0.217(PSI)
MIN 0.000(PSI)
STS OK
Test $CE
MOD $00
MAX 4.752(PSI)
MEAS 0.316(PSI)
MIN 0.000(PSI)
STS OK
Test $CF
MOD $00
MAX 4.752(PSI)
MEAS 0.233(PSI)
MIN 0.000(PSI)
STS OK
Test $D0
MOD $00
MAX 4.752(PSI)
MEAS 0.329(PSI)
MIN 0.000(PSI)
STS OK
Test $D1
MOD $00
MAX 4.752(PSI)
MEAS 0.217(PSI)
MIN 0.000(PSI)
STS OK
Test $D4
MOD $00
MAX 4.752(PSI)
MEAS 0.354(PSI)
MIN 0.000(PSI)
STS OK
Test $D5
MOD $00
MAX 4.752(PSI)
MEAS 0.348(PSI)
MIN 0.000(PSI)
STS OK
Test $D7
MOD $00
MAX 4.752(PSI)
MEAS 0.000(PSI)
MIN 0.000(PSI)
STS OK
Sec Air Mon 1
Test $E1
MOD $00
MAX 86.51(LB/M)
MEAS 0.63(LB/M)
MIN 0.27(LB/M)
STS OK
Test $E2
MOD $00
MAX 0.72(PSI)
MEAS 0.02(PSI)
MIN 0.00(PSI)
STS OK
Test $E3
MOD $00
MAX 95.05(PSI)
MEAS 1.14(PSI)
MIN 0.14(PSI)
STS OK
Test $E4
MOD $00
MAX 2.90(PSI)
MEAS 0.04(PSI)
MIN 0.00(PSI)
STS OK
Test $E5
MOD $00
MAX 95.05(PSI)
MEAS 7.59(PSI)
MIN 2.35(PSI)
STS OK
Test $E6
MOD $00
MAX 2.90(PSI)
MEAS 0.03(PSI)
MIN 0.00(PSI)
STS OK
Test $E7
MOD $00
MAX 95.05(PSI)
MEAS 2.01(PSI)
MIN 0.75(PSI)
STS OK
Test $E8
MOD $00
MAX 95.05(PSI)
MEAS 0.31(PSI)
MIN 0.23(PSI)
STS OK
Test $E9
MOD $00
MAX 0.00(PSI)
MEAS 0.00(PSI)
MIN 0.00(PSI)
STS OK
Misfire Data
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 1
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 2
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 3
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 4
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 5
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 6
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 7
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cyl 8
EWMA Misfire Cnt
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Misfire Cnt Last
MOD $00
MAX 65535(cnts)
MEAS 0(cnts)
MIN 0(cnts)
STS OK
Monitor $E1
Test $E8
MOD $00
MAX 5930.1(°F)
MEAS 167.0(°F)
MIN 167.0(°F)
STS OK
Vehicle Information
VIN
#1 MOD $00: JTEBT14R058027606
CVN
#1 MOD $00: D1 9B F0 A1
CAL ID
#1 MOD $00: 33532200
IPT
#1 MOD $00:
OBD Mon Cond 5
Ignition Cycles 31
Cat Comp Bank1 7
Cat Cond Bank1 5
Cat Comp Bank2 7
Cat Cond Bank2 5
O2 Comp Bank1 2
O2 Cond Bank1 5
O2 Comp Bank2 2
O2 Cond Bank2 5
EGR Mon Comp Not Available
EGR Mon Cond 5
AIR Mon Comp 9
AIR Mon Cond 1
EVAP Mon Comp 2
EVAP Mon Cond 1
runner43
12-15-2010 03:35 PM
Quick Reply: P0420/430
